Indicator light relocation (figured it out)
http://www.customdynamics.com/led_button_head_bolts.htm
When we started, we took blue painters tape and masked off the top of headlight and anywhere else you may drip solder, or hit with a wrench or a screwdriver. Also be careful with the center punch and the drilling, not to slip. We then took a compass and scribed a line parallel with the trim ring on the front of the headlight, the distance back to where you want them positioned. We then determined the center bolt location on the top of the headlight and measured off either side to where the other 4 lights will be and made all the appropriate marks. We center punched each hole location and started drilling out the holes one at a time and increasing the size of the bit until it got to the proper size for the threaded part to just slip through the hole, but not too loose. After all the holes were drilled, we filed the edges of the holes we just drilled and then prepared to drill the hole out the back of the lights for the additional wires. I purchased a small rubber grommet (35 cents), at my local hardware store and after drilling this hole, and filing it smooth, we put the grommet in place. After determining the hot and ground wires off the original wires, and marking them, we dropped the bolts in place, placed a rubber O-ring on the bolt on the inside of the headlight bezel and tightened it down with the nylon nut they supply with the LED lights. We then pulled the LED button head bolt lights wires, out the hole we just drilled in the back of the headlight and made a nice soldered connection with heat shrink around each to the original respective corresponding indicator light wire off the harness. (We disconnected it from under the dash to give more play to the wires for this purpose). We had slipped a piece of heat shrink over the entire wiring job that we did before making the connections, but later removed it because it looked too bulky and just looked like crap. I ordered some pre slit wiring harness sleeves (Black wrap-it sleeving by Russell) from J&P, to finish the job off more neatly.
http://www.jpcycles.com/productgroup...=Harley&page=7
We then reconnected the wiring harness under the dash, put the dash back on, put the headlight back together and re-adjusted it, and called it a day. We had maybe three hours into the whole project, but it was definitely worth it to relocate those dang lights and make them presentable. I had seen some of the others that had been done here and although they looked good, it just wasn't quite what I wanted. My brother and I looked the bike over and though what better place than to stick them in the headlight. After all, they were on the eyebrow cover to begin with.
Swampy
differant bike but thats nice check mine!!!!
http://s158.photobucket.com/albums/t...sh-lights2.jpg
