Can the front brake lever position be adjusted?
Old Nov 5, 2007 | 07:16 AM
grandpawmoses's Avatar
grandpawmoses
Default Can the front brake lever position be adjusted?
08 FatBob. The front brake lever has too much travel (half way) before the brake starts to apply. It stops fine at about 3/4 way, it's just alien to my grip. If it weren't hydraulic it would be an easy adjustment. FYI, it's not a "soft" pull, it actuates in the same position every time.
Old Nov 5, 2007 | 08:53 AM
Sharknose's Avatar
Sharknose
Default RE: Can the front brake lever position be adjusted?
Have you bled the line and topped off the master cylinder? (Or did you just assume that it was done correctly at the dealership?)
Old Nov 5, 2007 | 09:50 AM
grandpawmoses
The master cylinder is full (my first check). I haven't bled the lines but it doesn't feel like air in the line either. It's solid stopping at the same point every time, just a long pull before it starts braking. I was wondering if there was a hidden "slop" adjustment between the lever & the piston.
jekyllandglide
Apr 15, 2015 10:25 AM
stevemaman
Sep 11, 2014 05:46 PM
TXagENGR
Mar 11, 2012 11:27 AM
01fatty
Aug 29, 2011 10:44 AM
hockey8787
Apr 8, 2008 07:15 PM
