Fork oil change Question
Old Nov 12, 2007 | 08:25 AM
ctsbob's Avatar
ctsbob
Default Fork oil change Question
First I am seeing alot of the SB's with the black covers for the lower forks...did i miss the memo on where to get these? Second..the oil change that is needed for the forks seems likes a lot of work ( limited tools and no garage!). Does anyone think that maybe it is possible to drill a hole and place a small fitting on the bottom to allow for easy draining of the fluids? Is this a structural issue? Did Harley Design this to be superior to the older style of drain plug? Or rather is is a design that pushes you into the stealer? Thanks for any help on this.
iclick
Aug 16, 2018 10:16 AM
Terrabella
Jul 9, 2013 10:43 PM
Emdog
Jun 29, 2011 01:28 AM
Tinmanpope
Oct 26, 2010 02:00 AM
emece
Sep 20, 2010 01:14 PM
