its broken
Old Nov 19, 2007 | 02:47 PM
twhitey's Avatar
twhitey
Default its broken
Well my 07 SB is at the Dealership, they cant find the problem. So unknown down time!!!
Bike had bad head shake while on the hwy. Slowed down problem went away, sped back up and constant shake that progressed to untolerable levels. It has a vibration in the pegs and bars at all speeds even with the clutch in while coasting.
Anyone else have this prob?
Old Nov 19, 2007 | 02:56 PM
harleyxlc's Avatar
harleyxlc
Default RE: its broken
Motor mount?
Old Nov 19, 2007 | 03:47 PM
lolife's Avatar
lolife
sorry to hear that............... . . . . .........................keep us posted.......... . . . ..
Old Nov 19, 2007 | 04:01 PM
Steve Zodiac's Avatar
Steve Zodiac
Lots of things could cause this problem and it can be very difficult to diagnose. I had it once years ago and it turned out to be wheel alignment. There are many faults that could cause this problem including:
Wheel balancing (might have thrown a weight )
Faulty or unevenly worn tyres
Different settings on each shock
Faulty or leaking shocks
Wheel bearings
Steering head bearings
Swing arm Bearings
Do you have a screen on
Luggage can make a difference in several ways ie loading, aerodynamics or both.
Damaged or cracked frame or swing arm (unlikely but poossible)
Old Nov 19, 2007 | 04:11 PM
DougsDyna's Avatar
DougsDyna
Sorryto hear, hope they find the source......................
DougJ
Old Nov 19, 2007 | 04:51 PM
mdog2222's Avatar
mdog2222
I'd check the motor mount but I figure that the dealership thought of that first... but then again who knows with those guys
Old Nov 19, 2007 | 07:17 PM
hk_shooter's Avatar
hk_shooter
Motor mounts, wheel balance/weights. Sounds like you were nearing the death wobble stage, there. Not a good place to be. Let us know what it was.
Old Nov 20, 2007 | 06:01 AM
twhitey's Avatar
twhitey
Well they called said there is diffently a problem, its gonna take a while. Then called back 5 hours later and said they checked everything they could think of it must just be normal. So i am going to talk to their master tech this morning, he was off yesterday.
Old Nov 20, 2007 | 06:44 AM
dyna07custom's Avatar
dyna07custom
Dont think its normal and sounds like it could be dangerous PRESS THEM!
Old Nov 20, 2007 | 06:45 AM
gmc1999's Avatar
gmc1999
[quote]ORIGINAL: twhitey
typicial bulls*it from the techs.
