Riser
Old Nov 19, 2007 | 05:02 PM
Malc_F's Avatar
Malc_F
Default Riser
Im thinking about fitting a straight riser to my 2000 fxdx, any ideas what size riser i can go to using the stock cables and wires?
I was hoping for a 4"1/2" rise.
Old Nov 19, 2007 | 05:11 PM
mdog2222's Avatar
mdog2222
Default RE: Riser
4.5 inch risers will work fine with drag bars
[IMG]local://upfiles/28108/F6FDFC2F1E574CAE860342721AD7F279.jpg[/IMG]
Old Nov 19, 2007 | 05:44 PM
thecabinboy's Avatar
thecabinboy
Default RE: Riser
I like your 2 stroke avatar Malc_F
Old Nov 19, 2007 | 05:48 PM
Malc_F's Avatar
Malc_F
Default RE: Riser
I like the idea of the drag bars mdog, i take it yours are fitted with no change to wires/cables? I was going to keep my stock black bars, but them drags look pretty good.
Cheers cabinboy, i like it too!
Old Nov 19, 2007 | 07:37 PM
JRK5892's Avatar
JRK5892
Default RE: Riser
you can make your own and just go up as far as your cables will let you... it is real easy! i can show you how to do it... i made mine here is what they look like
[IMG]local://upfiles/26534/6AE90A42FB2C46259CC08C3B4C9524BC.jpg[/IMG]
[IMG]local://upfiles/26534/172DCB118F634D3FBB14397498F54686.jpg[/IMG]
Old Nov 19, 2007 | 10:34 PM
stell55chevy's Avatar
stell55chevy
Default RE: Riser
i put 4 1/2" risres on my 06' superglide with mini apes. i like the look. just the right height too.
Old Nov 19, 2007 | 11:30 PM
20LowRider02's Avatar
20LowRider02
Default RE: Riser
I have 4.5" straight risers on my 02 FXDL with the stock bars and cables. No problem. Wouldn't go any higher though.
Old Nov 20, 2007 | 03:34 AM
Malc_F's Avatar
Malc_F
Default RE: Riser
Thats good, 4 and a half was the max I wanted to go!
I spose I better pull the tank off and see if theres any slack wire under there as well to make the job easier.
Old Nov 20, 2007 | 09:24 AM
madden23's Avatar
madden23
Default RE: Riser
All the cables will be fine with 4.5" although you will probably have to bend the front brake cable a little.
Old Nov 20, 2007 | 10:34 AM
kk6pg's Avatar
kk6pg
Default RE: Riser
I put the 4.5's on my SG with stock bars and all I had to do was loosen the clamp and relieve the stress on the front brake hose.
Just remember to protect the tank before you start.
