pre fill oil filter ?
Old Dec 25, 2005 | 03:34 PM
streetbobjim's Avatar
streetbobjim
Default pre fill oil filter ?
when changing the oil on my car, i usually pre fill the oil filter with new oil so that the oil pressure will come up more quickly ; the pump does not have to fill up a completely empty filter. Is it a good idea to do this when changing the filter on a harley? or is it better practice to fit a completely dry filter
Old Dec 25, 2005 | 04:15 PM
1200c's Avatar
1200c
Default RE: pre fill oil filter ?
My service manual for the harley says to prefill.
Old Dec 25, 2005 | 05:17 PM
bobcowan's Avatar
bobcowan
It's impossible to fill the filter before installing, beacue it sits horizontal. Add what little you can if it makes you feel good (I do). But I don't personally see that it would make much of a differance either way.
Old Dec 25, 2005 | 10:14 PM
paulie's Avatar
paulie
I've never prefilled any oil filter and I never have had a problem with any engines. You have oil in the critical areas on start up so it really isn't necessary in my opinion.
Old Dec 29, 2005 | 01:20 PM
1200c's Avatar
1200c
It's impossible to prefil it completely, but not impossible to prefil it. You can still put oil in it and let the filter element soak in the oil. Then you can fill it 1/4-1/2 of the way and screw it on. It has worked for me.
Old Dec 29, 2005 | 03:40 PM
duet's Avatar
duet
I filled mine filter about 1/2 full then eased the strap on the right handle bar and let the bike lean over so that the filter could be intalled with out leaking.
FOCI
Oil Archive (no new posts)
Jul 5, 2017 01:41 PM
BigBobbyD
Jul 13, 2012 05:17 PM
PLEIKU69
Jul 29, 2011 09:26 AM
Chips
Dec 9, 2009 07:22 PM
PWHOG
Mar 30, 2006 02:21 AM
