question for wide gliders
Old Dec 1, 2007 | 01:45 PM
VenturaChop's Avatar
VenturaChop
Default question for wide gliders
whats up guys...im currently in the middle of lacing a 21 inch wheel on my bob.....was wondering if any one put a larger tire like a 120 on there 21 with the stock wheel???? i really would like a larger tire in the front.... any info would be great
Old Dec 1, 2007 | 03:09 PM
Topspin's Avatar
Topspin
Default RE: question for wide gliders
My bike is new but I'll be searching for a bigger front tire setup when I'm ready for tires.
Old Dec 1, 2007 | 03:44 PM
VenturaChop
nice ride top spin........... bump
Old Dec 1, 2007 | 03:59 PM
reh13's Avatar
reh13
If you're talking about the stock (narrow) rim, no. If will fit, but it will also want to come off the bead. If it pops off at speed, you're going to encounter a serious problem.Most of the 21" rime for the 120 tire are 3 1/2", but you could run a 3" without any problems. And don't measure your rim outside edge to outside edgeand think you have a 3" rim. Rim width is measured bead to bead.
Old Dec 1, 2007 | 04:04 PM
reh13's Avatar
reh13
By the way, even if it stays on the rim, you're going to have some pretty short tread life.
Old Dec 1, 2007 | 04:05 PM
VenturaChop
sht so where can i get a 21 inch rim????? i cant seem to find any
Old Dec 1, 2007 | 05:07 PM
reh13's Avatar
reh13
Iassume you're wantinguse a stock hub, and lace up a wider rim on it. I'd call HogPro and ask them if they'll sell you the rim. I know they can build the wheel for you, andI canonly assume, they'll sell you just the rim.
Old Dec 1, 2007 | 05:20 PM
VenturaChop
just called man they dont carry any wire wheels....only premade stuff.......i just need the rim......
Old Dec 1, 2007 | 08:13 PM
Rebel Ryder's Avatar
Rebel Ryder
I would think that would be dangerous.
anything other than common 21x2.15 is gonna be hard to find or expensive like custom. I run a 21x2.15 and luv it!
its not that bad [8D]stick a metz on front and maybe upgrade/lower your front susp. if not. 19s or 21s are all I'll touch.
you will adapt nicely. good luck w/the lace!
Old Dec 1, 2007 | 08:23 PM
VenturaChop
you dont get a weird ride with the narrow 21....ive always heard that they follow groves and jerk you around
