* HOW TO * under fifty bux *
Old Sep 18, 2011 | 04:46 PM
  #1761
TeamMudd's Avatar
TeamMudd
with all the lay own plate brackets, side mount brackets, custom brackets, i tried to think a hair simpler......
now if this has been covered in the last 175 pages, i apologize! some of the pics, and pages refused to load with my great ultra low speed connection.
well a guy i work with was trying to sell me his factory modified lay down plate bracket for $50.... ok, not a bad deal, but i knew there was a more "efficient" way to do this..... (by the way the wife calls that "CHEAP")
well i took the factory mount off, held the plate up to the factory bracket (using the 3 mounting holes as guides), drilled 1/4" holes in the plate, then i took a piece of 1/4" rubber and drilled 3 holes in it as well, to match the plate holes. put the bolts through the plate and the rubber "spacer" and re mounted the plate onto the fender.
"Efficient" and effective!
next is the horn..... got to free them JUGS!!
thanks again for every one that has contributed to this lengthy thread!!
Old Sep 20, 2011 | 08:29 PM
  #1762
Quadancer's Avatar
Quadancer
Default Leather grip covers
I was getting tired of my foam handlebar grips due to the crack in the foam on one, where my fingertips would sit.
I priced out grips and they start at $57 and go up.
Got an idea looking at some leather grips...I had some soft thin leather I got on Fleabay, cut it into squares the circumference and width of the foam. Made holes down two sides with a hole punch and hammer, cut strips of lacing
from the piece and laced them on myself for nothing. I may wet them down and let them shrink a bit too.
Plush as can be.
Old Sep 25, 2011 | 01:52 AM
  #1763
HemiOrange's Avatar
HemiOrange
I wanted to mount a cig lighter in an inconspicuous spot both for quickly plugging in my Battery Tender and for whatever else I wanted to use it for. So I bought a lighter socket at the auto parts store. I already had the rubber expansion insert from a boat project that I used to secure the mount in the upper left corner into an existing frame hole. I cut the mount out of about .120" plate.
Next I mounted it, but discovered the seat bumper needed some clearance, so I made a cut-out for it.
Here it is mounted and hidden.
Old Sep 25, 2011 | 08:57 AM
  #1764
TeamMudd's Avatar
TeamMudd
looks good! great place to hide it. i only have one suggestion maybe........ for a hidden look, peel the white decal off the front, then it will be even more hidden ;-)
that's just an idea. but if you want to leave it, that's why these are our bikes, personal preference.
once again great location great set up!!
Old Sep 25, 2011 | 11:49 PM
  #1765
Ventana's Avatar
Ventana
Originally Posted by mud
Thanks for the compliment mike. Appreciate it.
Here's another one of those zero dollar pieces.
I know you've done one, but I don't think you wrote it up??
Side mount plate bracket....
Lots of folks like these, I don't, I'll never run one.
But, they are real easy to build.
Mud... you're a great man and a cool dude for fabbing these things for others to use even though you'd never run them yourself.
My bike thanks you... and so do I.
Old Sep 26, 2011 | 12:01 AM
  #1766
Ventana's Avatar
Ventana
Originally Posted by RudeDog
Terry was kind enough to sticky the thread on top.
Thanks Terry!
Mud, here's your link to the seat covering thread:
http://www.clubchopper.com/forums/sh...ad.php?t=60692
There's already some replies from people willing to help you out. You can either join or shoot me the replies you would like to submit and I'll relay that information.
I've also got 4 PMs for you to read.
Sticky is great but posting keeps it on top for those that use the "New Posts since last visit" option.
Old Sep 26, 2011 | 03:44 PM
  #1767
Ventana's Avatar
Ventana
Originally Posted by JaronB
License plate mount hole covers $15.00 delivered to my door. I bought 2inch tall and 1/5 inch diameter spikes on ebay.
Mud... how about "B U L L E T S" INSTEAD OF SPIKES? hUH? hUH?
Old Sep 26, 2011 | 05:47 PM
  #1768
mud's Avatar
mud
thank you sir. appreciate the compliment.
Old Sep 26, 2011 | 06:05 PM
  #1769
mud's Avatar
mud
that is the way to go Ventana
NYC or the Great State of Texas. bullets always win over spikes.
snapped these two bullet pix yesterday then rode out to Luckenbach.
my friend Bill says someone keeps stealing the tips off the antennas on his RoadGlide.
so he epoxied .243 ballistic tips on. good job. looks great.
...click the pix to enlarge the image...
Old Sep 26, 2011 | 06:25 PM
  #1770
SC-Longhair's Avatar
SC-Longhair
Mud, I really really hope that's not you attached to those boots.
