* HOW TO * under fifty bux *
Old Dec 21, 2007 | 09:54 AM
  #181
jsbridgew's Avatar
jsbridgew
Default RE: HOW TO - under fifty bux
...a can of Duplicolor High Performance Wheel Paint- Flat Black ....virtually IDENTICAL to Harley's texture black... and stronger, too
i just did my coil cover, emblem for battery cover, and fender struts
....will post pics when everything is put together
Old Dec 21, 2007 | 11:07 AM
  #182
stell55chevy's Avatar
stell55chevy
would love to see those pics.I really want to powder coat my mags black. I wonder if that paint would hold up. what do you think?
Old Dec 21, 2007 | 11:51 AM
  #183
jsbridgew's Avatar
jsbridgew
i gotta tell yah, stell.... it's strong stuff!.... all it suggests is that you apply it to a well cleaned surface....but i sanded, steel-wooled, and primed before i applied just to be sure
...i'll take some pics when i get home from work and i'll post them
Old Dec 21, 2007 | 11:55 AM
  #184
stell55chevy
I might try it on a test spot. maybe do the outside or inside hub part of mag for now. just to see if it will hold up. I am sure it will take a lot of prep to do the rims, but I thinkthe black would look great. on the other hand, if I take off the rims for powder coating, that gives me a great excuse to go get the 180 tire for the rear I have been drooling over. ove 10000 miles on the existing tire, so it is about due. thanks for the info.
Old Dec 21, 2007 | 02:16 PM
  #185
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Think of it this way, even if it doesn't hold up as well as a good powder coat job.
You can buy a hell of a lot of the stuff for a lot less money, and you won't have to sit looking a a unicycle you can't ride for two or more weeks waiting for the wheelto come back from the coaters.
Old Dec 21, 2007 | 02:27 PM
  #186
stell55chevy
it sure would be cheaper if I go that route. I may give it a try. I will post after to let you guys know how it went.
Old Dec 21, 2007 | 03:13 PM
  #187
JRK5892's Avatar
JRK5892
be sure you cover or better yet REMOVE your bearings... a little paint will cause your wheels to lock up if they are in the bearings... do not take chances brother... i had a old honda 750 lock up on me that i pulled from a barn... WOW... bike stops and YOU don't! i make it a point now to either replace or repack all the bearings on my Honda CB jobs...
Old Dec 21, 2007 | 03:31 PM
  #188
stell55chevy
good advice. i'll make sure to watch out when I do the job.
Old Dec 21, 2007 | 05:11 PM
  #189
lee's Avatar
lee
cheap old school footrests chop the end off a couple of railroad pins,now the trick to keep it cheap get a mate to drill them out at work.saving you alot of cash on drill bits.
[IMG]local://upfiles/8786/3DCE2B13B8DA4C71BD2844F0FE7EE1FF.jpg[/IMG]
[IMG]local://upfiles/8786/961D0B1FF2C140389D1CC2D423ADF7FA.jpg[/IMG]
Old Dec 21, 2007 | 05:13 PM
  #190
JRK5892's Avatar
JRK5892
I like the do it all case on the batter box! great idea!!! i always have mine on my belt... not for long!
