* HOW TO * under fifty bux *
Wanna see it when you're done.
mud
Thanks good advice. I found some keychains on ebay for 2.50 apiece 38 special keychains made from real bullits, I think it will be easy enoughwith these goddies 8 bucks for 2, is also cheap enuff.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=280084148723
I have a tank from a 07 SuperGlide with a dent in the side.
The tank is black.
This tank would save someone some money if they was going
to do the tank mod like Mud has done to his.
I would take 50.00 plus shipping.
Thanks MDodson
You gotta get under 50 though.
49.99??
mud
Keep us posted Thomas.
mud
Smiley
Speaking of bullets -
Bullet holes for the belt guard.
Inspired by the JpanKnees sickle Grunge
http://www.badland.net/new_informati...ldyna_last.htm
First step, I tape the belt cover and layout spacing.
I don't want the bullet holes lined up in a straight line,
so I am staggering them off center an eighth inch on each side of the centerline.
below is layout at the nose end.
The small red circles are indicating the spotwelds for the mounting bracket.
I worked the layout around these, might as well leave the spotwelds as HD fused them.
below is layout at the tail end.
I reduced the penetrations to .50 caliber when the radius starts.
penetrations on the rest are .700 Nitro Express
Again, the small red circles are locating HDs spotwelds.
Next shown is the boring operation for the .700 Nitro Express size holes.
I start from the outside, penetrating about 3/4 of the thickness.
Now, below, I turn the work over, and finish the penetration from the inside of the beltguard.
The 5/8" hole saw actually bores to about .700
As shown below, I spaced the big holes at 1 1/4",
and then reduced this to one inch at the tail end.
You can see here that this boring technique requires paint touchup.
I'll wait till the weather warms up a bit, only hit about 68F today.
Squirt some paint next week, supposed to get up into the eighties.
I'm happy with the results.
Layout the spacing carefully,
and have a good looksee before boring.
OK. Below. Install.
I like a light coating of White Grease on the grommets and bushings.
I left a bit on the grommet to show where, but the pic didn't come out that good.
Grease inside and outside of both the grommets and bushings.
Wipe off excess, you only need a light coating.
For the front bolt by the rear footpeg,
you get to use your ball end allen wrench.
Don't forget a little dab of blue loctite on all fasteners.
Oftentimes, I hear folks speaking of applying "a liberal coating of loctite".
A small drop is all that is needed. See below.
Below. Done (less paint).
I considered boring the top side as well, and I still may do it.
If so, they will not line up straight on with these penetrations,
They will be located between the centers of these,
so as not to over weaken this component.
I'd like to do a football using this boring maneuver (picked up some CanadaSpeak).
if anyone has one to part with, let me know.
G'day Mud,
No responses after all ya trouble . here's one: Turn ya stock mirrors 180 degrees. On the stock FXD & DC the mirrors are the widest part, if ya turn 'em you gain about 1 and a half inchs on EACH side, which makes a real improvement for splittin' lanes, ( I'm in traffic every day). It actually looks better too because they sit in tighter almost up against the master cyl, bit hard to read the "appear closer' warning, but i have memorised that message
cya when ya come down under Mud.
Graham.
thanks
zuma
