* HOW TO * under fifty bux *
Old Feb 8, 2008 | 09:02 PM
  #561
mud's Avatar
mud
Default RE: HOW TO - under fifty bux
mudindex
post# 1033 …… rear running lights ....... Posted by Citoriplus
post# 1045 …… J&S jack improvements.....Posted by mud
post# 1046 …… 12 Volt plug on the bike.......Posted by dklozik
post# 1053 …… fork stem nut clock....... Posted by chengdave2003
post# 1057 …… stripping and polishing primary, cam and clutch cover....... Posted by mud
.........1057 is missing some pix
post# 1062 …… polishing aluminium pieces....... Posted by RudeDog
post# 1065 ……tank lift......Posted by mud
.........1065 is missing some pix
post# 1069 …… quick release fuel valve....... Posted by lee
post# 1075 …… rocker box wrinkle black out....... Posted by boutellepc
post# 1081 …… video camera mount.......Posted by mud
post# 1085 …… high beam garage door opener....... Posted by Streets of Fire
post# 1089 …… video upload to YouTube.......Posted by vetto
post# 1091…… molex connector poking tool....... Posted by mud
post# 1092 …… AMP fitting release tool......Posted by mud
post# 1093 …… Deutsch fitting crimper......Posted by mud
post# 1094 …… wiring tail light.....Posted by mud
post# 1096 …… old school tunable baffles......Posted by vetto
post# 1097 …… rocker c seat modification....... Posted by robo01
CLICK BELOW for INDEXES
  #562
mud's Avatar
mud
Here is a tool for initial wheel alignment in the rear fork.
I used a six inch piece of 1/8 inch stainless round stock,
and a snug fitting o-Ring.
Grind one end to a blunt point then mark at 1 1/4" back.
Place the stock in a vise at the mark,
then bend it over and hammer down for a nice sharp 90.
measuring at the rear axle
a tool I made in 2007..........
a tool I made in 2010..........
my red mark below is the witness line.
Old Feb 8, 2008 | 10:04 PM
  #563
HOGRIDA_06's Avatar
HOGRIDA_06
ORIGINAL: mudpuddle
Here is a tool for initial wheelalignment in the rear fork.
mud
Yeah Buddy, I got one just like that in my box.
Old Feb 8, 2008 | 11:30 PM
  #564
mud's Avatar
mud
ORIGINAL: HOGRIDA_06
ORIGINAL: mudpuddle
mud
I figure you would have this one Brian.
What else you got??
Make your own tools is a great pastime.
mud
Old Feb 10, 2008 | 12:13 PM
  #565
WS6 Formula's Avatar
WS6 Formula
Trim to fit license plate
Remove plate, put aluminum tape over license plate mount, press down on tape to locate edges and thru holes, use a xacto blade to cut along inside edge of license plate mount, cut out thru holes, pull off tape and put on a cereal box, use scissors to cut out around the outer edge of the tape, cut out thru holes, align template to your license plate using thru holes, tape in place, use a die grinder with a file type bit and cut close to the edge, then put a piece of sand paper on your garage floor to use as a flat plate, sand the edges of your plate smooth and straight.
Before
After
Old Feb 10, 2008 | 01:27 PM
  #566
Dawg Rider's Avatar
Dawg Rider
WS6 Formula...the King of the Details
(but I did like the chrome shocks better)
Old Feb 10, 2008 | 06:45 PM
  #567
mud's Avatar
mud
ORIGINAL: WS6 Formula
Thanks Formula. Nice job.
I've copied a few of yours through the years,
and I know you got a million of em.
My license plate, I trimmed off about 1/4" all the way around
to make it smaller for the mudSickle application.
mud
Old Feb 11, 2008 | 12:03 PM
  #568
misterkidgo's Avatar
misterkidgo
Thanks for the index, Mud!
(bookmarked.)
Old Feb 11, 2008 | 01:31 PM
  #569
JRK5892's Avatar
JRK5892
MUD the index is awesome!!! looks great!
Old Feb 11, 2008 | 09:55 PM
  #570
mud's Avatar
mud
ORIGINAL: misterkidgo
(bookmarked.)
Yessir Mr.Kid. My pleasure.
Post up some pix if you have an opportunity.
Mud
