* HOW TO * under fifty bux *
Did not get the link Dog.
Doin it myself, for now.
When I find a seat maker /slash/ leather carver,
I will commission it out.
mud
http://www.clubchopper.com/forums/sh...820#post733820
Plus I thought I sent you a bunch of copies of the PM replies I recieved from that thread? I'll send those again. . . . . .
O.K., email sent.
I went with much the same setup as others, but used the screw holding the battery cover down as a mounting point for a flattened shelving bracket. Ran the wiring through under the seat. I had to cut and splice to get the wires out of the shield where they run halfway up the tank. This gave me enough length to get it under the battery cover. It is much louder, maybe because of no cover?
[IMG]local://upfiles/58191/9930DBD223D24D37A64C2EF3CC56F814.jpg[/IMG]
I've relocated mine, even bought a smaller horn, but it sounds like ****. I don't reallly care what it sounds like, because I never use it, but I'm worried I'll get hooked for it on an inspection sooner or later. Anyone know what i should be doing to get the horn to sound right?
I'll describe the super quick, easy,andcheap Lowe's brand adjustabletank lift as soon as I get a chance.
Is the sound quality good?
ahhhhhh ... thank you.
After lowering the rear of my FatBob, using the jiffy stand was a bit scary, the bike had very little weight on the stand and I often feared the wind could blow it over.
Heating and bending can remove the temper and make the stand weak, so the next best thing, by removing an 1/8" from the top of resting tab I was able to get the bike to "lean"
over about an inch and now feels as if there could be weight on the stand.
I blocked the frame so I could move the stand back and forth.
Verified the amount of material to remove, and made sure enough was left to hit the "stop" when extending the stand.
Using a cut off disk remove a uniform amount across the top of the "resting Tab", Return bike to floor and test.
Before Removal
After Removal
Use what ya got.
mud
Side Mount License Plate Bracket (Free)
I took off the stock bracket and sat down with my dogs and a six pack while watch an old episode of biker build off (with Indian Larry) for some inspriation. After about a half hour of bending around and trying to line the holes up, it eventually worked. Sorry I'm not more precise with how I did it but it's like one of those triangle shapped wooden puzzles with the golf tees that you have to remove. The only time you ever actually succeed you can't ever remember how you did itfor the next time.
Horn Relocate (45 hanging bracket)
I know a few people have done this but I thought I would throw in my two cents as well, I bought a 3" hanging bracket from an autoparts store put it in a vise and bent the end down 90degrees. Bolted it under the top bolt for the rear exhaust support bracket and it lays down under the battery box.
Thanks to everyone that's been posting here...keep'r between the lines.
That photo I took at Laidlaw's Harley Davidson in Baldwin Park, Californiaback on January 12 2008.
Owner said he did it himself and I haven't seen the bike since.
You might try posting in the pacific section of this forum and see if anyone knows the owner.
Much appreciated.
Good idea to post in the Pacific Room.
That is some of the best leather tooling etc that I have seen.
mud
