* HOW TO * under fifty bux *
Old Aug 20, 2008 | 10:24 PM
  #961
mud's Avatar
mud
mudindex
page 21 https://www.hdforums.com/forum/showthread.php?t=173504&page=21
post# 802 ……license laydown….........… jnslim007
post# 810 ……license laydown….........… BluBob
post# 818 ……lower kickStand….......… deanz
post# 824 ……tank lift….........................… Dawg Rider
post# 828 ……hide detachables…......… Dawg Rider
post# 834 ……pipe adaptation……........ tree88
post# 840 ……reRoute breathers…… HogGlider
page 22 https://www.hdforums.com/forum/showt...173504&page=22
post# 841 ……air cleaner…........................… HogGlider
post# 843 ……store accessories…........… XKROME
post# 857 ……pop rivit dash….................… joeld0803
post# 861 ……fork lock holder……............. chengdave2003
post# 861 ……extend hiWay peg….........… chengdave2003
post# 861 ……suck in turn signals…......… chengdave2003
post# 861 ……license plate backup…...… chengdave2003
post# 865 ……key fob control…….............. shawn e.
post# 866 ……camera mount on bars……128auto
post# 867 ……tieWrap magic…...............… icecaps
page 23 https://www.hdforums.com/forum/showt...173504&page=23
post# 887 ……spray paint…..................… expy
post# 891 ……storage…..........................… Streets of Fire
post# 902 ……touring helpers…....… XKROME
post# 914 ……forward control extensions…...............… Out1aw
post# 916 ……Twin Cam engine stand…............................… mud
post# 919 ……more forward control extensions…… Dingobob
page 24 https://www.hdforums.com/forum/showthread.php?t=173504&page=24
post# 924 ……headlight reMount…… damfino
post# 938 ……hiWay peg mounts…… ackman1968
post# 946 ……find specific URL….… mud
post# 956 ……reminder…......................… mud
page 25 https://www.hdforums.com/forum/showthread.php?t=173504&page=25
post# 962 ……Oil Pressure Gauge Mount…......… mud
post# 966 ……relocate mirrors…...............................… HogGlider
post# 971 ……extended shift rod….........................… Out1aw
post# 972 ……relocate idiot lights….......................… Out1aw
post# 981 ……breather reRoute parts list…… mud
post# 982 ……12 volt energee source…................… mud
Old Aug 21, 2008 | 10:44 AM
  #962
mud's Avatar
mud
When I built my 121 inch motor I wanted to add an Oil Pressure Gauge.
The kit that HD sells for this has a real nice liquid filled gauge,
and a nice housing, but it is designed to hang off the pipe Side,
sticking way out in the wild blue yonder.
I want the gauge tucked in on the hornSide.
First step, cut off one mounting tab,
so the bolt holes will match up to the other side of Rocker Cover.
I used an old gasket to get the spacing,
and weld the tab back on, about one eighth inch inboard (below).
So, that's easy enough.....
HD supplies a nylon line that is only long enough for mounting on the pipeSide of the motor.
So, for now, I am running copper line to the hornSide location.
First, I built a couple little brackets for Adel Clamps.
Below, I've laid out pattern on a piece of scrap stock,
for two brackets.
Here below are the two brackets.
They will hang off the lifter housings...........
On the right (below) the tubing comes up from the oil pressure fitting.
Across and through the Adel Clamps,
then on the left, the tubing heads over to the hornSide of the motor.
Next picture, you can barely see the Adel Clamp on the transmission top cover.
From there the tubing runs up to connect to the gauge........
Last picture shows the gauge tucked in nice and close.
Old Aug 22, 2008 | 12:38 PM
  #963
JRK5892's Avatar
JRK5892
Originally Posted by mudpuddle
another breather reroute..
If there is any interest, I will post these up.....
I would love to see more of this!
Old Aug 22, 2008 | 09:48 PM
  #964
amish's Avatar
amish
is the mounting tab for the gague mounted under or ontop of the rocker box cover?
so this will work on my 07 bob even though they say it wont fit?
where does it connect to will it effect the anything on the bike?
and pice of how to hook it up
thanks
Old Aug 22, 2008 | 11:20 PM
  #965
mud's Avatar
mud
thanks
On top of the rocker box cover,
like the picture below..........
connects where the red tape is in front of the cam chest
in the picture below........
Old Aug 26, 2008 | 02:08 PM
  #966
HogGlider's Avatar
HogGlider
Here is another cheap/free modification. You will need a torch for this to make it easy and get the right bends to the mirror stems.
I have a great field of view from behind now versus having them mounted above the bars, plus it kind of gives the bike a lower/sleeker appearance now.
Old Aug 26, 2008 | 02:44 PM
  #967
vetto's Avatar
vetto
Mud, about those copper oil lines to the gauge...can you tell me more about the fittings and what kind of line that is? it looks smaller than refrigerator water supply lines.
Old Aug 26, 2008 | 07:36 PM
  #968
mud's Avatar
mud
Good job. Good thinkin.
Can't forget the fireWrench.
good tool to have in the arsenal.
mud
  #969
mud's Avatar
mud
vet, the copper line is 1/8 inch.
the fittings are really common to any oil pressure gauge install,
whether it be automotive, HD, or otherwise.
mud
Old Aug 27, 2008 | 09:24 PM
  #970
RudeDog's Avatar
RudeDog
Great mod HogRider! I tried using my mirrors wrong way around (on the mini apes) and all I saw was my arms.
After seeing what you've done I may have to pick up another set of mirrors and give this a try. I've been tempted to paint mine black anyways.
Thanks!
