Alternator Output
Old Dec 7, 2007 | 03:19 PM
moose98's Avatar
moose98
5th Gear
Default Alternator Output
Can anyone tell me what the charging output is for a 2008 Dyna? I have a 2008 Street Bob and am looking to get some heated clothing but am not sure of how much I can put on. If anyone knows the total operating load on a stock bike, that would be helpful too.
-Moose
Old Dec 7, 2007 | 04:13 PM
darkdyna06's Avatar
darkdyna06
Default RE: Alternator Output
When the alternator imploded on my 06, I replaced the rotor and stator with 07 parts. If I remember correctlt the old one (06) was 28 amps, and the new one (07 and later) is 40 amps. Since the factory gives us a 12 volt accessory plug under the seat, I dont think you will hae a problem running your gear. Theres still plenty of older gm and ford cars running around with 40 amp charging systems.
Old Dec 7, 2007 | 05:40 PM
DougsDyna's Avatar
DougsDyna
Should be no problem for you. I run a cigarette lighter, HD heated grips, warm gear heated glove liners, and a warm and safe heated jacket liner with absolutely no problems.
Can't remember/locate alt specs right off, but the 06 amp output is either 28 or 32 amps. Don't know the 08 specs.
DougJ
Old Dec 7, 2007 | 10:48 PM
06dynablack's Avatar
06dynablack
the 06 stator is 38 amps listed on chicago harley part number is 30017-01a
Old Dec 7, 2007 | 11:27 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: 06dynablack
Thanks for correct info
Kytann
14
Dec 27, 2020 08:12 PM
acman308
EVO
Oct 21, 2016 12:25 PM
Grouser62
2014-2024 Touring Models
11
Sep 23, 2016 11:06 AM
big cahuna
Dec 1, 2014 07:55 PM
Ned69
Dec 31, 2006 01:30 AM
