ThunderMax, PC III-USB, SERT
Hi guys,
Let's see if wisdom and experience maketheir way to this message.... in the mean time, I´m sure there are many around with 07's and 08's with the Race Tuner in their wardrobe or in a box in the garage.... maybe they'd care to take a look at their bikes and see if the O2 sensors are still connected or by-passed.... It would give us a hint.
The O2 sensors remain connected with SERT. Only with the
PC III are they disconnected.
The data you produced is clarifying, and makes sense, but I'm still not sure how the SERT works; it actually looks like it allows the engine to run in an open loop most of the time and it only runs closed loop when the engine is over 14 to 1, closer to 14.3 to one; that would mean that the SERT works almost like a PC III-usb, since for most of the bikers riding, you are either accelerating or in a load situation where the engine needs more fuel thus the O2 sensors are removed from the equation.
I now believe I did the right choice when I purchased the TMax with the autotune and the wide band sensors. Still, only tme will tell, but the delivery of both the Rineharts and the TMax is just a couple of days from now.
Thanks to all who answered and of course I will keep you informed on how the bike runs. To tell you the truth, I'm a bit scared on how loud the Rineharts will be; they could end-up being a bit too much for me and my neighbours.
Spanish Flyer
Personally the TMax is the best way to go, unless you just enjoy paying someone to dyno tune your bike.
richen the mixture. Pulse Stretch: This is when the injectors are held open for an additional
proportional (P) time to increase fuel delivery.
position (TPS) sensors, to affect the ECM’s outputs.
injector pulse width and ignition advance in each table location or cell.
the AFR. Map-style tuners use target AFR tables.
adjustment range or resolution for the rapid AFR changes and front/rear cylinder differences
that high-performance cams typically cause.
extreme of AFR requirements.
timing?
areas? A Y has emission regulation implications. Some require additional purchase of O2
sensor eliminators.
open-loop areas? Open loop is accelerator “pump” (especially off-idle) and above threequarter
throttle or three-quarter maximum rpm.
opening columns from 0 to 100 percent in the fuel and ignition tables. Lower number of
bands reduces dyno tuning time. N = is for indirect tuners, rpm resolution is not user
identifiable.
For instance, the Fi2000 has one-rpm breakpoint creating two-rpm bands; the Techlusion
two breakpoints, three bands. N means indirect tuners; rpm resolution is not user
identifiable. The designation 250, 500 means user selectable rpm bands, while 250/500
means 500-rpm bands above 3000 rpm. Using the widest effective band reduces dyno
tuning time.
his bike, to set in a base tune, and, in the case of the auto-tuners, to make adjustments
later. Requiring the use of a computer adds one point.
idle, cruise, full throttle, and decel pop tests. A number in this column is an estimate in
hours of the time it takes a skilled operator to perform a tune of both cylinders over the full
range of rpm and throttle openings on a dyno equipped with dual AFR sensors. A U means
the device is unadjustable. An N means the manufacturer does not provide the information
needed to effectively adjust the product on a dyno. An M means a dyno is the safest way to
tune maximum throttle openings and rpm.
Sorry, I do not, I found that a while back and i think it was from an American Iron Magazine article.
Attachment 256104
Types Of EFI Tuners
O2 Offset:
Mild:
sensor eliminators.
identifiable.
tuning time.
Thanks for the great info...My local Drag Specialties dealer suggested the T-Max also...Do you think the T-Max with Auto Tune would be the best way to go?...From the research that I've done, seems like it would eliminate a lot of trial and error.....Thanks again for the reply...
You would have to check compatibility with your '12 FXDC ...
