Thunderheaders On a Fat Bob?
Old Dec 25, 2007 | 01:15 AM
stagolee's Avatar
stagolee
Default Thunderheaders On a Fat Bob?
So I'm pounding the asphalt with my vanilla stock Fat Bob and I'm aching to upgrade my exhaust. I'm getting lost in the pack (under the roar of the loud pipes all around me) and the 1000 mile mark is fast-approaching.
So, this is what I want to know...
What would I need to do to the common Dyna version of the Thunderheader to adapt it to my California Fat Bob?
Are the Fat Bob mounts different? I've heard they are.
As for the O2 sensor... is there anything to prevent me from welding a sensor to the common Dyna version of the Thunderheader?
Anything else I need to consider?
Thanks.
Old Dec 25, 2007 | 05:13 PM
SPECIAL ED's Avatar
SPECIAL ED
Default RE: Thunderheaders On a Fat Bob?
Thunderheader makes pipes with with the O2 sensor bungs already in the pipes they have since 06.I haven't seen a Fat Bob up close so I can't comment on the mounting.However,
If the Fat Bob uses a standard Dyna frame it hasn't changed since 06 so it should bolt right up.Good luck.
Old Dec 28, 2007 | 04:51 PM
stagolee's Avatar
stagolee
Special_Ed, thanks for the response. I see that you're right about there being O2-equipped ThunderHeaders. That's great news.
I still unclear on whether the FXDF frame is different. I suppose I'll get around to checking with the mfg. to see if they've proven the application yet.
Again, thanks.
Old Dec 28, 2007 | 05:06 PM
storm8732's Avatar
storm8732
The frames are the same....the only difference is if you are using the stock head pipes as the slip ons mount differently on the fat bob....if you put on a complete exhaust system you will be good to go. Don't forget the needed remap.
Old Dec 28, 2007 | 10:53 PM
stagolee's Avatar
stagolee
ORIGINAL: storm8732
Great. That's what I was expecting. I'm thinking I'll probably swap out the complete stock exhaust. Just by eyeballing the thunderheaders on my friend's '06 Wide Glide, I'm thinking the Tommy Gun Heat Shield would still be usable. We'll see.
His pipes look something like this:
^^That's not his bike, though.
Thanks for the info.
Old Jan 14, 2008 | 04:53 PM
stagolee's Avatar
stagolee
Here's the stock photo from Thunderheader.net (model 1031)
Anybody know whether the Tommy Gun heat shield will fit the above pipe configuration?
Old Jan 14, 2008 | 10:53 PM
db252's Avatar
db252
Here are some pics of a thunder header on a Fat Bob in black and chrome. Both Fat Bobs are Vivid Black. The dealer did this and had no problems.
[IMG]local://upfiles/49144/8872EF3E66CE43C9BCEAEBE36E78A203.jpg[/IMG]
[IMG]local://upfiles/49144/EC70F3D943074D47AB1F36C410040909.jpg[/IMG]
Old Jan 15, 2008 | 08:41 AM
hmmr's Avatar
hmmr
wow, that pipe doesn't fit too well. waay out and low.
Old Jan 15, 2008 | 11:11 AM
stagolee's Avatar
stagolee
ORIGINAL: db252
Thanks for those photos. That chrome looks great.
ORIGINAL: hmmr
I see what you mean, but I think it's by design - although I could see it being less-than-attractive for riders with forward controls.
Old Jan 15, 2008 | 11:52 AM
cadillac's Avatar
cadillac
Ive got forward controls on my 2000 Dyna and a Thunderheader. They arent a problem for either the driver or the rider. Pipe fits very well.
[edited to add pic of Dyna w/Thunderheader]
bob
[IMG]local://upfiles/24889/95166BCB6D2D487A894062F95CE606F4.jpg[/IMG]
