removing reflector
Old Dec 31, 2007 | 09:02 AM
djwhaley's Avatar
djwhaley
Default RE: removing reflector
I used a hairdryer and a plastic scaper so I wouldn't scratch the paint then a little lighter fluid to get rid of the adhesive
Old Dec 31, 2007 | 09:17 AM
Lumpy63's Avatar
Lumpy63
ORIGINAL: rounder
blow dryer... some dental floss...
Will the mint stuff work....?
Old Dec 31, 2007 | 09:26 AM
dyna07custom's Avatar
dyna07custom
hair dryer and monofiliment fishing line 8lb test then wd40 to remove glue take your time easy but tedious wax when done
Old Dec 31, 2007 | 09:28 AM
dyna07custom
oops sorry you have denim no wax or wd 40 just keep heating and peeling
Old Dec 31, 2007 | 10:23 AM
DougsDyna's Avatar
DougsDyna
I heard they would peel off at 160 mph............... Tried that 1st, but realized I peeled off at just a little over 120 mph.
Had to resort to hairdryer and WD. I did mine in the winter of 2006 outside with 20 mph winds blowing. it took awhile.
DougJ
Old Dec 31, 2007 | 10:39 AM
arnold's Avatar
arnold
At about 40 degrees, I took a red shop rag, eased it under one end and pulled steady, they peeled right off with a little force. Took WD40 and a soft rag and buffed off the stickum, went to car wash and washed off WD40, easy as pie.
Old Dec 31, 2007 | 11:16 AM
DougsDyna's Avatar
DougsDyna
ORIGINAL: arnold
Your FatBob looks killer!! Willie G musta had a lot of help.
DougJ
Old Dec 31, 2007 | 08:01 PM
Clutch66's Avatar
Clutch66
After reading this thread, and having nothing to do, I used a hair dryer, slowly pealed them off, rolled the big chunks with my finger then finished it with the "Goo Gone" - total time- about 20 minutes per reflector- no scratches at all - I did it while watching the Pats set their record - Thanks Guys.
Old Jan 1, 2008 | 09:05 PM
Bobber S's Avatar
Bobber S
I have the black denimand removed themwith no problem or damage to the paint.
Procedure I used :
1. Pour very hot waterover the reflectors.
2. Take a PLASTIC putty knife and slowly (keeping the pressure UPunder the reflectorbase) run the knife under the reflectors.
3. Remove the glue residue with windex, first rubbing in with your fingers to loosen the gunk, thenwipe offwith a cotton cloth.
Old Jan 1, 2008 | 09:09 PM
rjmac53's Avatar
rjmac53
Glad it worked out
DR.M3TAL
Oct 4, 2016 04:40 PM
crotchrocket
Aug 27, 2015 10:51 AM
Chris Creole
Jun 17, 2014 10:29 PM
tygr
Jul 30, 2010 02:16 AM
ny06fxdb
Apr 29, 2007 11:00 PM
