fender reflectors
Old Apr 29, 2007 | 06:33 PM
ny06fxdb's Avatar
ny06fxdb
Default fender reflectors
Does anyone know how to remove the rear fender reflectors without screwing up the black denim paint.I tried searching the topic with no luck.The front ones came off easy with fishing line.
Old Apr 29, 2007 | 06:36 PM
hd_sob's Avatar
hd_sob
Default RE: fender reflectors
I pulled on them from top to bottom until they came off. Best to park it in the sun first, or warm it up with a hair dryer...
Old Apr 29, 2007 | 06:53 PM
wasp's Avatar
wasp
aint no way you did a search on that and nothin came up.lol
anyways get some 3m adhesive remover from wally word, spray on let soak then use some dental floss cut through the
adhesive. after reflector off keep usin 3m adhesive and all the gunk will come off without harming your paint.
Old Apr 29, 2007 | 08:49 PM
Rauzer's Avatar
Rauzer
I took mine of with just a hair dryer.
Old Apr 29, 2007 | 08:52 PM
Dyna07's Avatar
Dyna07
Can i have the reflectors ?
CyclChyk's Avatar
CyclChyk
I ripped mine off and used the arm and hammer magic eraser for the goo. Came right off and the paint was mint!
Old Apr 29, 2007 | 09:14 PM
gorilla's Avatar
gorilla
I used a heat gun, low setting. Then an alcohol wipe to remove the sticky stuff.
Old Apr 29, 2007 | 10:06 PM
RazorFXDB's Avatar
RazorFXDB
I just took mine off the other day. I've got the black denim bob.
The dental floss maneouver will take them off in about 3 seconds. Really ...no heat, no nothing, just saw at it with the floss and they come right off.
The glue was a bit different. I used goo-gone. Put some on a rag and then applied to the glue. It took some patients, but just keep applying and rubbing and it will eventually eat away at the glue. No damage to the paint.
Also, the glue has like a padding or something in it that you can scrape off to speed up the process, but you have to be careful not to go too deep, or slip and scratch the paint.
Have fun.
Old Apr 29, 2007 | 10:40 PM
ny06fxdb's Avatar
ny06fxdb
Thanx everybody. I got them off .No problem (3m adhesive remover).
Old Apr 29, 2007 | 10:55 PM
LAZYBOY's Avatar
LAZYBOY
i used dental floss. just use it like a saw and cut thru the adhesive foam. getting the left over off is a pain but no big deal
