Solid riser bushing for apes, any benefits?
Old Dec 31, 2007 | 03:55 AM
Azgunner's Avatar
Azgunner
Default Solid riser bushing for apes, any benefits?
I've got Ø1", 16" apes & have the polyuerethane riser bushings. I know some guys have used the solid bushings, is there any noticeable improvement or benefit to the solids over the polys? Just wondering.
Old Dec 31, 2007 | 04:24 AM
xxxflhrci's Avatar
xxxflhrci
Default RE: Solid riser bushing for apes, any benefits?
Less flex, more vibration felt in the grips. I'd rather have a little bar flex.
Old Dec 31, 2007 | 06:56 AM
GlassBikerNC's Avatar
GlassBikerNC
I'd much rather have the poly's than solid. Much more vibration with the solid bushings.
Old Dec 31, 2007 | 08:09 AM
Dizzzy's Avatar
Dizzzy
I'm putting a set in ...I have 18" bars. I had solids on my shovel with the same bars...the vibration didn't bother me, but I might be spoiled now.
Old Dec 31, 2007 | 09:16 AM
reded's Avatar
reded
I'd say go with the solid due to flex. My brother has18" apes on a WG and last summer one of the riser bolts that comes up thru thetree broke while he was moving the bike around in the garage. After examining the bolt, it was obviously that it had flexed so many times that it just got weak and snapped.Coulda ended up ugly if it wouldahappened at 70mph!
Old Dec 31, 2007 | 11:02 AM
tree88's Avatar
tree88
I aint had a problem with mine. some people say the vibration would be an issue, but the length of the apes takes care of most of it. I installed some heavier rear-view mirrors on mine (i know sounds dumb- but bar end weights are what they use to quell vibration on sportbikes- so i gave it a try) and the tops of the bars are almost perfectly still (about like stock bars and riser bushings) the only thing that vibrates bad on mine is the clutch lever (worn bushing).
ole_phart
Jan 12, 2019 06:44 PM
Voony
Sep 4, 2011 10:15 AM
soft 02
Apr 3, 2011 01:17 PM
frankiefire702
Nov 16, 2009 07:53 PM
hd_sob
Jul 30, 2006 02:16 PM
