10" Apes, Replace Riser Bushings?
Old Jan 6, 2019 | 06:54 AM
ole_phart's Avatar
ole_phart
Default 10" Apes, Replace Riser Bushings?
Hey All, G'Morning,
I'll be putting 10" apes on my '18 Low Rider. Should I put in solid riser bushings or will I be ok at that height sticking with the stock rubber? Thanks!
-jeff
Old Jan 6, 2019 | 07:03 AM
Hey Man's Avatar
Hey Man
I always use solids with apes. You have more of a fulcrum to make the bars move back and forth with apes and rubber bushings.
Old Jan 6, 2019 | 07:07 AM
Cygnusx51's Avatar
Cygnusx51
Go with the poly’s. The rubber may seem fine at first but with that extra leverage the bars give you, they will wear out much faster. May as well do it now while you got stuff apart.
Old Jan 6, 2019 | 07:08 AM
nobodyknowsme's Avatar
nobodyknowsme
I think what you should be looking for are poly bushings.
Old Jan 6, 2019 | 09:16 AM
ole_phart's Avatar
ole_phart
You guys are great, thanks! I just ordered 'em from Revzilla.
-jeff
Old Jan 6, 2019 | 01:59 PM
MyFavRk's Avatar
MyFavRk
Great post , I was thinking the same thing . I'm going to be putting on 14" Ape's on this spring . Good to know ! Thanks for asking ..
Old Jan 6, 2019 | 02:44 PM
Dalt10's Avatar
Dalt10
Put the HD poly ones on mine. Thought I would get a lot of vibration thru them but don't work great.
Old Jan 6, 2019 | 02:45 PM
Ragtop's Avatar
Ragtop
I used the stock bushings with my Wild Ones 10" mini apes, no problems at all.
Old Jan 6, 2019 | 06:13 PM
Huskers's Avatar
Huskers
I used poly in mine. No vibrations and no issues.
Old Jan 6, 2019 | 08:38 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
You can get by with stock, but good Poly bushings would be MUCH better and they are not expensive. When I installed Yaffe 10 Inch Monkey Bars I bought Drag Specialties Poly Bushings for like $25.00.
At first you will feel more vibration through the bars. But after a while it becomes normal and you don't even notice it.
