pullback risers
Old Jan 7, 2008 | 01:33 PM
phog light's Avatar
phog light
Default pullback risers
hi, thinking of fitting 4" pullback risers with the stock bars on an 07 fxdc, can anyone tell me if they,ll fit straight on or will there be issues with cable lengths,cheers
mick
Old Jan 7, 2008 | 01:50 PM
lilrooster76's Avatar
lilrooster76
Default RE: pullback risers
Wierd, i was just thinking the same thing.....would be nice to know
Old Jan 7, 2008 | 02:07 PM
TOMMAY's Avatar
TOMMAY
No problem on my 06,seems like I had to move the brakeline clip. Believe there's a pic in my gallery.
Good Luck
Tom
https://www.hdforums.com/photo.asp?p...=6&apage=2
Old Jan 7, 2008 | 02:08 PM
beaverretriever's Avatar
beaverretriever
ORIGINAL: phog light
mick
Just did the bars and risers on my 08 FXDC. The 4" will be to short and may interfere with your tank gauge.
I ran 5 1/2" pullbacks with drag bars. Im 5'9" and its perfect. All stock cables will work with the exception of the brake line. Its to long in my opinion but to some it would be fine.
I would post some pics but have not yet figured that out yet. Would be happy to email you some pics.
Old Jan 7, 2008 | 04:11 PM
bikerdog134's Avatar
bikerdog134
i got them on my 05 fxdci. no problems
Old Jan 7, 2008 | 04:25 PM
Delmarksman's Avatar
Delmarksman
Just installed 4.5" Pullbacks on my 08 FXD.
Only issue is the Handlebar mounted Speedo now sits straight up.
Not difficult to see, but somewhat awkward to look at.
That being said, it does sit higher so I don't have to to look down as far to see it.
And it did move my bars
Old Jan 7, 2008 | 04:29 PM
Delmarksman
That is, it did move my bars to where I wanted them.
Old Jan 7, 2008 | 05:18 PM
ShoreRider's Avatar
ShoreRider
I put 4.5" pullback risers on my '07 FXDC. No wiring changes at all, some minor modification to the rear brake line (remove the triple tree bracket and gently bend the brake line). Other than loosening the l/r controls and adjusting the turn signals, was one of the easiest installs I've done. I did replace the stock bushing and bolts with a flush mount bolt and poly bushings.
Sig pic show the outcome...be glad to post some closer views if anyone is interested.
Old Jan 7, 2008 | 08:07 PM
murphdog's Avatar
murphdog
This is my 07 with 4.5" pullback risers and the stock handlebar. As others have said, all thecables and wires are fine.The brake line is a little tight, but it'll work if you bendthe hard line at the master cylinder. I ended up replacing my brake line with a braided Goodridge cause there wasn't enough slack to rotate the handlebar to where I wanted it.
[IMG]local://upfiles/2952/994D5B1F61834FEAB324802721D80BA6.jpg[/IMG]
07 super glide
Feb 25, 2016 07:35 PM
Brettfullthrottle
Softail Parts
Apr 11, 2015 04:41 PM
CatalyticCarbon
Jan 14, 2012 09:20 AM
mynzbtr1
Oct 19, 2008 03:32 PM
aviator
Oct 19, 2007 11:11 PM
