headlight
Old Jan 15, 2008 | 09:12 AM
bikerdog134's Avatar
bikerdog134
Default headlight
looking to change headlight on my 05 glide. any advice, opinions, and or pictures would be appreciated
Old Jan 15, 2008 | 09:14 AM
jmpancoast's Avatar
jmpancoast
Default RE: headlight
The one shown is my Sig is from Eastern Performance. I was $95.00 shipped.
[IMG]local://upfiles/23085/C74581B9FFC14614937349589E595E36.jpg[/IMG]
Old Jan 15, 2008 | 09:33 AM
rounder's Avatar
rounder
05... so you are top mounted....
There is a guy who replaced his headlight and it goes above the trees.
thing is I do not believe you can do much... you can get a chrome bezel(if you don't have the custom).
I added a new trim ring to mine...H-D visor trim ring in sig. below
You could do an accutronix triple tree kit and get it with the bottom mount then the skys the limit...
mid or wide trees with 3deg rake maybe. $$$ though.
Old Jan 15, 2008 | 01:34 PM
bikerdog134
im trying to do away with the visor. hoping i can just drill a hole and use bottom mount but im open to options and sugestions. yuurs looks good with the trim ring might be an option. it would sure save me some bucks. thanks for the feedback
Old Jan 15, 2008 | 08:58 PM
Azgunner's Avatar
Azgunner
I drilled my bottom tree & mounted a wide glide headlight when I still had the narrow glide front end. Easy to do. I've got a wide glide front end on my Lowrider now & put a 6 1/2" dia. Springer headlight on it. It has more of a teardrop shape to it & looks very nice. Had the body powdercoated gloss-black & left the trim ring chrome.
[IMG]local://upfiles/11153/4B5E67D9801245279DD7D8A9D43A9E58.jpg[/IMG]
Old Jan 15, 2008 | 09:16 PM
Sarge4life's Avatar
Sarge4life
The sky is the limit when it comes to headlights. You can make just about anything work with a little ingenuity. I removed the "bucket" and mounted a piece of angle iron to span the gap. I covered it with diamond plate to hide the angle iron and wires. I drilled a hole and mounted the light on top. Not everyone may like it, but it is definitely unique.
Old Jan 15, 2008 | 10:51 PM
rounder's Avatar
rounder
thought of something ... Saw a 883L with a new headlight and Nacelle kit. I think it was even a H-D accessory. It looked cool.
Nacelle = like a fatboy or Road King.
Old Jan 16, 2008 | 08:08 AM
bikerdog134
azgunner, thanks, thats what i had in mind. i was hoping someone did that.found a light i like and pretty much wanted to see if someone drilled their trees. thanks all for your feedback
Old Jan 16, 2008 | 08:41 AM
SgtThump's Avatar
SgtThump
I'm in the EXACT same boat. My headlight is top mounted to that ugly *** "eyebrow." I want to install a longer bullet style headlight, but they all seem to be for bottom mounted rigs. Do you need to do anything to protect the metal after you drill a hole to prevent rusting or no big deal? I wonder if I could drill that hole without taking anything apart? Maybe...
I'd like to sh*tcan that eyebrow and mount my idiot lights somewhere else too, but haven't figured that one out yet either.
Old Jan 16, 2008 | 01:03 PM
Azgunner's Avatar
Azgunner
You trees are aluminum, they wont rust. Just un plug the idiot lights & toss 'em. I'm sure you know how to tell when your'e in neutral & you have a switch that turns high beams on/off, turn signals you can usually see if their still blinking, etc. I did drill a hole in my dash & popped the oil pressure light in there. As far as I'm concerned it's the only one that is important.
paulmj
2018+ Softail Models
Jun 18, 2019 10:35 AM
clap
Jan 23, 2014 07:53 PM
rns348
Feb 24, 2013 09:02 PM
sonar_chris
Dec 30, 2007 07:52 PM
traveler
Product Reviews
Jun 26, 2005 12:37 PM
