Custom mounted my saddle bags
picture below was before and the Signature pix. is after.
first I got the brackets... found in the aisle with the door hinges they come in a bag of 4 and are 2" long with two holes for mounting screws.
next I got 2 4 packs of 1" long allen bolts size 10-24.
bag of nuts and washers to fit the bolts.
total cost about 8 bucks.
marked the bags and drilled holes in the back for the bolts to attach the brackets.
mounted brackets on the inside then outside of bag... some silicone and a washer and nut to secure inside brackets.
aligned bag to the supports then installed other bracket and tightened to have it clamp down on the support.(the bracket will bend to wrap itself around the support.
feels secure... I can push down on the bags with my 200 lbs of weight and they do not move at all.
pix of one of the brackets from in the bag:
Rounder - What kind of bags are they and where did you get em?
