Stupid Question ?
Old Jan 23, 2008 | 07:19 PM
  #31
domenicp7's Avatar
domenicp7
Default RE: Stupid Question ?
I was going to dyno tune all along. I feel the info from the dealer and when to do it was not up front. I just hope I can get a reputable tunner to do it. Cost is not a problem, I just want to get what I pay for. In Dallas, Houston or Austin who is good?
Old Jan 23, 2008 | 08:01 PM
  #32
Topspin's Avatar
Topspin
ORIGINAL: man4mopar
ORIGINAL: Trotter
Top.... If your running the 2007 Street legal mufflers and the S.E. Air Cleaner with the download than your fine... After Market pipes and A/C... the 2007 Stage 1 Download Is'nt enough...
No offence and not trying to start anything. But do you have a AFR chart or have you run a AFR check with a bike set up SE air cleaner and SE II's or some other free flowing exhaust? If you have no chart what did you find in AFR's?
I ask this because if using the SERT or a download and utilizingthe narrow band sensors. The majority of the map is closed loop unless changed by tuner with SERT. WOT,high loads and cold starts are open loop. Butmajority of mapis inclosed loop wheremost ride. And that will be a 14.7:1 ratio. Which some feel is too lean, I disagree but not the point. So if one believes that, then to get out of the 14.7:1 ratio one needs a SERT,PCIII,Tmax,DTT or some other full fuel management system. And unless that system uses a O2 sensor for self adjustment one needs a AFR meter to tune them self or have it done by a tuner. Canned maps in a open loop system get you close maybe.
WTF?
I'm lost as a green dick in a pickle jar!
Where is my paid off 06 2006 VTX?
Old Jan 23, 2008 | 09:52 PM
  #33
RAWHIDE07's Avatar
RAWHIDE07
so Trotter,the plug ins from nightrider are not for performance?
Old Jan 23, 2008 | 10:28 PM
  #34
mud's Avatar
mud
ORIGINAL: RAWHIDE07
OK, I'll take the bait RAWHIDE07 -
what's nightrider?? the yellow plug wires, or????
mud
Old Jan 24, 2008 | 06:05 AM
  #35
04fxdwgi's Avatar
04fxdwgi
Also having a FI TC 88, I went w/ the V&H exhaust, K&N A/C and PCIII USB. After installing, I
connected a hand held dual channel temp data recorder, 1 lead to each exhaust pipe. Drove
around a bit and returned and analyzed the data on the recorder and found rear cylinder runs
hotter than front. Tweaked the PCIII on the laptop and repeated a few more times. Got
exhaust temps VERY close and tweaked some more, till " Seat of Pants " dyno said " That's
the Spot ". Brought to dyno tuner and he tweaked for 10 minutes and it was done. Tuner
told me she was near perfect when it came in, due to exhaust temps being near identacle
and realy didn't need the dyno time.
Don't know how technical you are, but the data loggers can be had for around $ 250 bucks.
I just happened to have one for my work.
Ride safe
Old Jan 24, 2008 | 06:18 AM
  #36
Trotter's Avatar
Trotter
The Plug In's are not for performance... but to adj the A/F at idle and steady throttle from 14.7 to 14.2 which is better... but 13.2/13.7 is better... Which your Dyno Tech can achieve for each Cyl.
Old Jan 24, 2008 | 06:22 AM
  #37
DougsDyna's Avatar
DougsDyna
Skip, What are you calling a "plug in"?
DougJ
Old Jan 24, 2008 | 06:23 AM
  #38
Trotter's Avatar
Trotter
The question was
Why someone would go out and spend 13,000.00 to 18,000.00 on a bike then spend 200.00 on a A/C and another 300.00/500.00 on a Exhaust system and alot of other moneys on chrome stuff, But over look the most Important part of the exhaust equation spending 300.00 to 500.00 to get the bike tuned so the bike runs Cooler andat it's full potentialfor a long life....Is it because it's money spent on someting that you cant look at..?Because you can definatly feel the differance if it's done right... over justa download A/C and pipes...
Old Jan 24, 2008 | 06:56 AM
  #39
Dynaflyer's Avatar
Dynaflyer
ORIGINAL: Trotter
The question was
Hey, I resemble that remark! Did a High flow aircleaner,SE Pre EPA Slip on's and a SERTcanned map.Waiting ona few parts to arrive (fuel gauge with gray wire) Bike has been sitting a while waiting for parts. Seems everything I go to purchase HAS to be ordered. yet one can get any motor clothes anytime WTF !Example, a speed nut .99 cent item common to all dynas, not in stock.
Gezzus chrysler man!! Once installed it's off to the dyno for a final tune. Weather has been brutal here, Single digits High of 8* today. Hot diggity dog. NOT.Just don't want to expose the bike in a unheated trailer.Schedualed tohave the scoot in the dealer next week for a dyno tune.
Discussed at lenght with the tech and It appears he knows his Chit. Can't wait to eeek out all the performance possiable. But the most important is the cooler running Machine.
Old Jan 24, 2008 | 06:57 AM
  #40
DougsDyna's Avatar
DougsDyna
ORIGINAL: Trotter
The question was
I know, but I asked what are you calling a "plug in"??Believe I know what I will be using in the future, and I know an excellent tuner.
