Pegdragger & the Tornado
Old Jan 15, 2006 | 12:43 PM
ecvjohn's Avatar
ecvjohn
Default RE: Pegdragger & the Tornado
ORIGINAL: ******
John, John, John, what happened to the Mine is Stock, this custom stuff is overated? haha
ORIGINAL: ecvjohn
ORIGINAL: Axholio
{hijack}
ecvjohn I just wanted to comment that everytine I see that pic of your Scoot my mouth waters!
{/hijack}
Thanks, I wish I could take full credit but the tins and paint were like that when I got it.
I think theres a pic of when it came home chromeless in my gallery, it'll have a windshield on it if its there.
Dang, I never thought I'd get caught, it was tough living knowing my bike was different yet claiming it was stock just one forum area down from here.
Whoa is me and the tangled web I weave.
Old Jan 15, 2006 | 02:41 PM
grizzly's Avatar
grizzly
ORIGINAL: ecvjohn
ORIGINAL: ******
ORIGINAL: ecvjohn
ORIGINAL: Axholio
{hijack}
{/hijack}
I KNEW IT!!!! Bike looks great man!
Old Jan 15, 2006 | 03:24 PM
chapds's Avatar
chapds
Great post...
Old Jan 15, 2006 | 03:54 PM
fisherdude's Avatar
fisherdude
ROFLMAO Try a can in the tailight
ORIGINAL: Grover
I really screwed up the other day. I sent for HighPerformance NASA approved Hologen light fluid for my RK. It was only $49.95 plus S&H.
I removed the trim screw from the headlight ring, inserted the 10 gauge hypodermic needle and pushed on the top of the aerosol can to install the fluid.
I waited until the noise stopped and then detached the needle and put the screw in.
I followed the instructions and set the dimmer switch to dim and started the bike. I was up to 30 mph and flipped the headlight switch to bright. OH MY GOSH. I was like I had stepped on the brake. The increased headlight pressure had stopped my bike. Luckily I had my foot on the brake or it would have pushed me backwards!
Needless to say I took the tinfoil liner out of my helmet and made a reflector to put over the headlamp to redirect the force.
When I got home I drained the fluid out by removing the trim screw.
Be careful what you buy and install. Especially if it is recommended by someone you don't know very well.
Old Jan 15, 2006 | 03:59 PM
Sooee's Avatar
Sooee
A great way to save batteries - go around your bike and tie knots in all the loose wires, it prevents the electricty from escaping and (as a by-product) stops polluting the roads with all those wasted electrons.
Old Jan 15, 2006 | 04:32 PM
ecvjohn's Avatar
ecvjohn
ORIGINAL: Sooee
Just finished doing this and also crimped off all of the vacuum lines as I figured it would keep the bike from sucking me to it everytime I go into the garage.
I also plugged the exhaust outlets so I don't lose any compression while its just sitting there.
Old Jan 15, 2006 | 05:01 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
I never fell for all that crap. Everyone knows that if you get a good layer of wax on your bike you have less wind resistance. Less wind resistance equals more speed and better gas milage. Also I've got dual headlights. Everyone knows that if it has the word "dual" in front of it it's gotta be a high performance product.
My old shop teacher in highschool had a Rambler American. He told us it was a high performance car because it had dual headlights, go fast hubcaps and racing stripes. He always kept a good coat of wax for less wind resistance.
I figure with my new Race Tuner, 211 cams and a good coat of wax I should be able to break the 90 hp mark
Terry
Old Jan 15, 2006 | 05:29 PM
ecvjohn's Avatar
ecvjohn
So if I wax my headlight and duct tape a maglight to my bars I should be all set. Dual headlights and less wind , now thats living.
Man this performance stuff is easier than I thought.
Old Jan 15, 2006 | 05:57 PM
firstonein 1's Avatar
firstonein 1
How about 2 coats of wax for more protection
Or is it that the second coat just takes off the first? Anyhow too much wax makes a bigger profile and will affect your gas consumption.
Old Jan 15, 2006 | 06:10 PM
pococj's Avatar
pococj
ORIGINAL: Sooee
Remember a certain politician running for Prezzidink about 6 years ago once accused the electric companies of letting electricity run out on the ground to charge higher prices. We had slipknots so we wouldn't get caught! How'd he figger it out?
