Getting Progressive 412s, Question?
Old Feb 2, 2008 | 07:22 AM
Naz_Man's Avatar
Naz_Man
Default Getting Progressive 412s, Question?
I am getting ready to order a set of 11 inch progressive 412 shocks for me bike
When looking at the catalog it says get the HD set for loads over 225lbs and for loads under 225lbs get the STD set.
( HD= Heavy Duty STD= Standard )
I weight 190 maybe a little less.... Should I just go with the HD anyways?
Another question is will I have to change my kick stand?
Thanks for any input!
Donnie
Old Feb 2, 2008 | 07:25 AM
Naz_Man's Avatar
Naz_Man
Default RE: Getting Progressive 412s, Question?
Oh yeah I forgot..... Is 269.99 a good price or can I get em cheaper? Is so please post a link!!
Thanks again, Donnie
Old Feb 2, 2008 | 07:37 AM
jmpancoast's Avatar
jmpancoast
I have the 412 11" standard duty on my SG. I weigh 195 and am very happy with them. I ride with the wife on the back (two-up weight 325) and they still do OK. I have seen some say the heavy duties are needed for two up. I have also seen some say the HDs make for a VERY stiff ride.
Eastern Performance has the standard dutyfor 195.00 shipped. Here's the link:
http://www.easternperformance.com/in...products_id=93
Old Feb 2, 2008 | 07:42 AM
Naz_Man's Avatar
Naz_Man
ORIGINAL: jmpancoast
Thanks for the info.... That link says THESE FIT DYNA MODELS 1991-2004......I have a 2005..... maybe still work?
Nice Price tho
Donnie
Old Feb 2, 2008 | 08:07 AM
jmpancoast's Avatar
jmpancoast
Here is the application chart from Progressive for the 05 FXDC. The ones in the Eastern Performance link are correct for your ride.
[IMG]local://upfiles/23085/ED943CBDA9D34FC4A9DBDD7C627B3422.jpg[/IMG]
Old Feb 2, 2008 | 08:15 AM
Naz_Man's Avatar
Naz_Man
Wow if I could only see that
Old Feb 2, 2008 | 08:29 AM
jmpancoast's Avatar
jmpancoast
here's a link:
www.progressivesuspension.com/prodSearchResults.aspx?yearID=2005&makeID=37&a mp;modelID=370
Old Feb 2, 2008 | 08:43 AM
Naz_Man's Avatar
Naz_Man
Thanks man!!
Old Feb 2, 2008 | 08:49 AM
Chipstah's Avatar
Chipstah
ORIGINAL: Naz_Man
Donnie
Donnie - I put 412 HD 11" on my bobstah along with Progressive front springs and lowered them to level out the bike - originally thought about the standard 412 shocks, but decided I was more than willing to get a really super handling set-up and to trade-off the stiffness issue. I'm 180 lbs and love the ride. But then I prize handling above a soft ride in all my vehicles and travel back country roads most of the time. So everything I own has heavy duty or upgraded suspensions.
You do feel all the road irregularities and learn to avoid the pot holes and big bumps, but will never bottom them out even at the softest setting (which is all I ever use), and you're all set with the HDs if you ever go two-up. I only ever ride solo, though. I am not into a cushy ride (or else I'd be on a bagger), what I wanted was to be more in control on the twisties and feel really planted and in the bike - not on it. Little or no noticeable trade off on smooth roads and hiways.
I haven't had any problem with the kick stand, am just careful on any slopes as she doesn't lean quite as much with the bike lowered. Try it without changing the kick stand first and see what you think.
Price wise, I paid about $190 from Motorcycle Accessory Warehouse. Just do your homework on the Progressive website first and make sure you have the right part numbers for your bike and whether you want chrome or black.
Good Luck!
Old Feb 2, 2008 | 11:59 AM
Ratbasturd's Avatar
Ratbasturd
Get the Heavy duty....
https://www.hdforums.com/m_2750192/tm.htm
