Tank lift kit...?
Old Jun 17, 2011 | 01:04 PM
  #81
SC-Longhair's Avatar
SC-Longhair
Originally Posted by Maddog63
Can someone send me a link to order Jackyl Tank Lift Kit, as I want to install at same time as I switch out stock bar to Apes.
Thanks
Can someone learn to use the forum search function?
Old Jun 17, 2011 | 07:41 PM
  #82
Flinter's Avatar
Flinter
I just installed one of Jackyl's kits on my Street Bob.
I really like it.
The only issue I have is that the cross over feul line is right against the frame now. I'm not sure if it's going to rub through eventually or not.
He did include a new (longer) fuel line with the kit, but man...I hate to remove those factory crimped clamps.
Old Jun 17, 2011 | 08:31 PM
  #83
pontiac69's Avatar
pontiac69
I really like it.
I thought the fuel line supplied is for the fuel tank vent line not the tank crossover line ( mounted underneath ). I have seen a post where you take a closed end wrench and bend the 2 metal lines comming out of the tank , bend them down just a touch so the fuel line doesnt rub the frame.
Old Jun 18, 2011 | 07:53 AM
  #84
Flinter's Avatar
Flinter
You may be right.
I'm considering just trying to slip a thin piece of rubber between the frame and line. If it stays put I should be golden.
Or, I could just install a little longer line and do it right. I just wonder why I haven't seen this issue in the other tank lift threads I've read?
The mount seems to be high quality and the look is awesome. I'm just not sure which route to take with the cross over fuel line...
limomike
Oct 19, 2016 10:16 AM
sickboy75
Aug 10, 2014 05:46 PM
LAFO
Feb 17, 2014 09:19 PM
heshua
Jun 25, 2012 11:51 PM
mea3pk
Aug 1, 2008 08:20 AM
