FIRST BIKE
Old Feb 6, 2008 | 11:11 PM
mia6952's Avatar
mia6952
Stage II
Default FIRST BIKE
JUST BOUGHT MY FIRST BIKE..IT'S A 1992 FXLR DYNA CUSTOM LOW RIDER...THE PROBLEM I'M HAVING IS THAT I HAVE TO JUMP START IT SOMETIMES......I JUST PUT A NEW BATTERY IN IT....BUT SOMETIMES THE WHEN I GO TO START IT THE SILINOID JUST CLICKS AND BARELY STARTS TO TURN OVER......i HAVE TO JUMP IT...I THOUGHT IT WAS THE SILINOID OR MAYBE THE STARTER...WHEN I JUMP IT IT RUNS FINE...AS LONG AS I START IT WITHIN A FEW IN MINUTES OF SHUTTING IT OFF..OVER NIGHT I HAVE TO JUMP START IT THE NEXT MORNING...ANY IDEAS?
Old Feb 6, 2008 | 11:42 PM
96 Wide Glide's Avatar
96 Wide Glide
Default RE: FIRST BIKE
DID YOU CHARGE THE NEW BATTERY UP BEFORE YOU INSTALLED IT?
Old Feb 6, 2008 | 11:44 PM
Clutch66's Avatar
Clutch66
O.K............we'll start with the basics.
Make sure all of the connections are CLEAN and tight on the battery, and on the starter.
Next, the "new" battery is the right size and amp. for a Harley?
Last but not least, is there a "drain" on the battery when the key is off. there shouldn't be. There are two ways to check this. One way is to dis-connect the battery over night and then connect it just before you try to start it.
The second way to check a draw on a battery is to disconnect one of the battery cables and connect a 12 volt test light in series with the cable and battery. If there is a draw, the light will light. This means something is onor stuck-on that shouldn't be.
If I can explain it better, let me know and I'll go into more detail.
C66
Old Feb 7, 2008 | 07:35 AM
rjmac53's Avatar
rjmac53
[align=center]Good luck.... Welcome from Nawlins !!![/align][align=center][/align][align=center][/align]
Old Feb 7, 2008 | 09:25 AM
mia6952's Avatar
mia6952
Stage II
THANKS FOR THE HELP.. I WILL GET A TEST LIGHT TODAY AND TEST THE POSITIVE CABLE TO SEE IF THERE IS ANY KIND OF DRAWW....IT'S RUNNING FINE NOW AND STARTED UP FINE THIS MORNING......YES THE BATTERY IS A HARLEY BATTER AND THE CONNECTIONS ARE GOOD.....I'LL LET YOU YOU KNOW THE RESULTS....ANY OTHER ADVICE WOULD BE APPRECIATED....THANKS
Old Feb 7, 2008 | 09:39 AM
07bobber's Avatar
07bobber
CONGRATS AND GOOD LUCK
WELCOME FROM SO CAL
Old Feb 7, 2008 | 10:15 AM
xmarine's Avatar
xmarine
Congrats and Welcome
+1 on what Clutch said about the terminals. Use a socket to tighten them down and not a Phillips screwdriver. My St. Bob was doing that and the (-) terminal was screwdriver tight, socket tight cured it.
xmarine
Old Feb 7, 2008 | 07:30 PM
WGRIDER's Avatar
WGRIDER
Welcome from Richmond,VA
Old Feb 8, 2008 | 12:29 AM
dynasty's Avatar
dynasty
wrong or bad battery, or you have something draining it down overnight. could be corrosion somewhere (at a connection or plug), not necessarily at the battery.
good luck with it
PROVIDER7
Dec 10, 2016 08:41 AM
Kevin714
Nov 19, 2016 07:45 PM
fignuton
Oct 11, 2015 03:24 PM
Aylor70
Nov 12, 2012 09:40 PM
MCTV
Apr 19, 2010 12:57 PM
