FRAME
Old Feb 8, 2008 | 01:41 PM
brogotee's Avatar
brogotee
Stage I
Default FRAME
WHAT'S UP . I WOULD LIKE TO PUT MY DYNA ON A HARD TAIL FRAME . YOUR TOUGHTS.AND HELP
Old Feb 8, 2008 | 01:43 PM
Roadrocket's Avatar
Roadrocket
Default RE: FRAME
Help-------None to offer.
Thoughts---Why???
RR
07bobber's Avatar
07bobber
Default RE: FRAME
I THINK IT WOULD LOOK GOOD
Old Feb 8, 2008 | 01:46 PM
daven9113's Avatar
daven9113
Default RE: FRAME
Lots of work! No issue with engine if it's an Evo Frame. You'll have to get a different tranny and oil tank. Plus all the sheet metal to go with it. Those are just major items. $$ can solve everything.
dave
Old Feb 8, 2008 | 01:53 PM
Livi1215's Avatar
Livi1215
Default RE: FRAME
No ideas just 0.2 cents. I 've been thinking of doing the same but with my sportster. They're are afew places out there with frames but,depends on how much your lookin to throw down.
Old Feb 8, 2008 | 01:55 PM
stell55chevy's Avatar
stell55chevy
Default RE: FRAME
maybe some sort of weld on to existing front piece of frame.
basically chop off swing arm and weld in back piece of frame. see old triumph chops for a round about how to.
Old Feb 8, 2008 | 01:56 PM
DeJavu's Avatar
DeJavu
Default RE: FRAME
You need to check out the online catalogs, when I was looking for rigid frames I believe there were some for Dyna rubbermounts. Frame will run you anywhere from $1,000-2500 depending on what you want. You would have a lot more choices if you go with a seperate 4spd box. Good Luck!
Old Feb 8, 2008 | 01:58 PM
07bobber's Avatar
07bobber
Default RE: FRAME
DEPENDING ON HOW YOU SET IT UP OF COURSE....I MEAN LOOK AT LOLIFES CUSTOM THAT THING IS SIK!!!
alfajuj
Custom Models
Nov 27, 2012 10:50 PM
GONZEE
Feb 13, 2010 07:40 AM
krismac23
Sep 2, 2008 05:56 PM
rounder
Aug 3, 2008 02:25 PM
kata
Jan 5, 2006 03:29 AM
