Chrome Bolts??
Old Feb 13, 2008 | 11:10 PM
tattoofreaksb's Avatar
tattoofreaksb
Default Chrome Bolts??
What are you guys using in your triple trees for the pinch bolts? I got my trees &lowers powder coated & was going to use chrome bolts instead of the stock bolts but the parts guy said the stock bolts are self tapping grade 8 & I wouldn't be able to get one in chrome. Would have gotten them coated if I would have known this. Anyone with any suggestions?
Old Feb 13, 2008 | 11:18 PM
fiend138's Avatar
fiend138
Default RE: Chrome Bolts??
Piant? Or see if you powder coater can through them in with anouther batch of the same color. Too bad they are not stainless.
Old Feb 13, 2008 | 11:24 PM
tattoofreaksb
Powder Coater (finaltouchpowdercoating.com) is about an hour drive for me so I was just going to see if I could use something else or maybe just take & paint them gloss black myself. I've pretty much replaced all other bolts with Diamond Engineering Groove series Stainless Steel bolts.
Old Feb 13, 2008 | 11:43 PM
Dynaflyer's Avatar
Dynaflyer
I Used a Highspeed dremel with the polishing compound that came with it. Polished them up and clear coated them with the little Auto clearcoat touch up.
I am not saying to do this but I did and it turned out OK.
Old Feb 13, 2008 | 11:44 PM
fiend138's Avatar
fiend138
Self tapping or not they should be a standard pitch and diameter. If you need me to I can pull a bolt and tell you what they are.
Old Feb 13, 2008 | 11:46 PM
DynaDon's Avatar
DynaDon
I have SS Hex Head in mine - believe thay are just 3/8" 16 TPI.
I spin them in a cordless drill with 320 then 600 grit wet / dry, then Mother's or Semi-Chrome on a clean rag. Polish up great. I preffer SS over Chrome. Rsn: chrome bolts don't always get chrome inside the hex head and SS can be polished inside - plus chrome will rust.
If I'm painting them, I spin them with 400 wet dry and paint with Testors flat or Gloss enamal model paint. Then after installed I touch up (where / if)the wrench marks. Not sure if Powdercoat holds up to tightening / loosening to well, over time so you may have to touch-up any way. If I'm spraying Single Stage Black I'll use the left over to paint bolt heads - with a brush tho.
Contrary to popular belief you CAN polish mild steel bolts. HD uses pretty good quality stock bolts. Polish same as above, just re-hit with Mothers to keep a protective coating on them. I do it all the time if I can't find a specialty bolt. If the bike is in a garage - no problems. Outside it takes a little more effort to keep them shinny - like SS.
Good luck dd
Old Feb 14, 2008 | 12:26 AM
tattoofreaksb
Thanks for the info guys. Very much appreciated.
Old Feb 14, 2008 | 12:35 AM
JRK5892's Avatar
JRK5892
+1 polish them... i pullled mine out one by one and put a buffing wheel on a old grinder... just sat there with a bit of rubbing compoung, polish, then sealed it with wax when i was done... put it back in and got the next one out... but i had alot to do... here is a pic of my buddy helping me out with some polishing... you can get the old bench grinder from either harbor freigh real cheap... i got this one from dads basement... it was his dads.... but it is perfect the motor is so warn it will stop turning before you burn the material you are buffing... PERFECT!!! you can polish any metal to almost chrome man... against the black... it just pops! nothing looks better thank black and chrome
[IMG]local://upfiles/26534/63AFC05CA93B40C5AA8EA8DD435B93C9.jpg[/IMG]
Old Feb 14, 2008 | 06:11 AM
jsbridgew's Avatar
jsbridgew
i know guys that have simply replaced them with chrome 3/8 X 16 X 1-1/2 inch allen head bolts without any issues....they threw some loctite on the end, and rode all season
also, if you replace them with torx heads (which they are)....the chrome ones are grade 8
...as far as self tapping goes....yes, they are, but only at the end where the final torque is given.... the trees are threaded from the factory ...also, look at any aftermarket "pinch" bolt for earlier years and you'll see they aren't self-tapped nor are they probably grade 8....most likely, grade 5
just my experience and thoughts
....incidentally, i replaced mine with grade 8 chrome torx heads
Old Feb 14, 2008 | 06:34 AM
jsbridgew's Avatar
jsbridgew
also, once you remove that pinch bolt the "self-tapping" concept behind them no longer serves a real purpose ....the tap has been made and the threads have been created
by the way, your 'bob looks badass, jrk!
