brake
Old Feb 16, 2008 | 01:10 AM
michaelvs710's Avatar
michaelvs710
Default brake
I was wondering if there was anyway to raise the brake pedal on the mids instead of being flat with my foot.If anyone has moved theirs let me know
Old Feb 16, 2008 | 01:29 AM
jefx's Avatar
jefx
Default RE: brake
You could heat it and bend it.
Old Feb 16, 2008 | 06:30 AM
jmpancoast's Avatar
jmpancoast
Default RE: brake
ORIGINAL: michaelvs710
There is a rod which goes from a pivot pin on the brake pedal to a threaded end of the rear master cylinder. Loosen the jam nut on the master cylinder end of the rod. If you rotate the end of the master cylinder where the rod threads, you can lengthen or shorten the rod, which in turn, raises or lowers the pedal.
I believe youneed torotate the end of the master cylinder clockwise to lengthen the rod and raise the pedal. The end of the cylinder has flats so a wrench can be used.
Old Feb 16, 2008 | 10:14 AM
bikerdog134's Avatar
bikerdog134
Default RE: brake
thats a good question. id like to do the same thing. i wonder how much you can raise it
Old Feb 16, 2008 | 01:31 PM
michaelvs710
Default RE: brake
ORIGINAL: jmpancoast
Thanks for the info I will be giving it a shot
Dazzauk
EVO
May 11, 2016 10:24 AM
MOSTWANTED
Jul 20, 2012 02:37 PM
PFIRE
Oct 15, 2010 08:35 PM
nkauf21
Jan 5, 2008 12:23 AM
colinjordan
Dec 11, 2006 08:22 PM
