forward control self install?
Old Feb 16, 2008 | 08:03 PM
Frog74's Avatar
Frog74
Default forward control self install?
Let me apologize in advance if this is a beat up subject. I am pretty new to wrenching on my 08 SG. I am looking to put forward controls on. Dealers want arm and a leg for labor. Is this a mod I can do myself with little knowledge or is it better to trust the dealer for this? Thanks for any help!
Old Feb 16, 2008 | 08:15 PM
Sc07Sbob's Avatar
Sc07Sbob
Default RE: forward control self install?
IMO...if you don't know much about working on stuff, I would let the dealer do it. I don't know if you plan on just cutting the shifter shaft off, or removing the primary to get it out, but either way, I think it would be best to let the dealer do it.....again, my opinion only!
good luck either way!
Old Feb 16, 2008 | 08:16 PM
Clutch66's Avatar
Clutch66
Well, if you can change a tire, or have any mechaincal ability at all, you should not have a problem if you use the H-D forward control kit.
I used it on my '05 and it took about an hour to do with Coke and cigarette breaks included.
It is pretty straight forward. The mid controls come off and the forwards go on in the frame bosses already welded on the front of the frame. Th H-D kit is all inclusive and has very good detailed instructions.
You should have no problem at all.
C66
Old Feb 16, 2008 | 09:12 PM
txtec's Avatar
txtec
it took me about 45 minutes ,but i just had a coke ,no smokes .i agree whith clutch, very simple install.
Old Feb 16, 2008 | 09:28 PM
57springer57's Avatar
57springer57
buy a manual and go for it
Old Feb 16, 2008 | 09:57 PM
darkdyna06's Avatar
darkdyna06
Pretty easy to do, and you do not really need to remove the shifter shaft from the primary. I used a bracket from the pre05 kit with a home made spacer and just bolted the old shift shaft to the center case bolt. Go for it...
[IMG]local://upfiles/21800/1579B8DD94784A81BC3CF0B03CBB42DE.jpg[/IMG]
Old Feb 17, 2008 | 12:10 PM
Frog74's Avatar
Frog74
Thank you for all the help. I will give it a shot. I thought I could get through it was just alittle worried about the shift linkage and the hole that would be left over.
Old Feb 17, 2008 | 02:45 PM
Frog74's Avatar
Frog74
I was just told that on the 08 model, that it is alittle more complicated because you have to remove the primary and clutch. is this true?? Please someone that has down this mod to their 08 Would greatly appreciate help. Also will the 05 kit work?
Old Feb 17, 2008 | 03:00 PM
jefx's Avatar
jefx
ORIGINAL: Frog74
That's what the dealer will do. That's why it's so expensive.
Shadetree guys just cut off the old shaft. There's been a few write-ups about it here, but the search is broken.
tysonb
General Topics/Tech Tips
Apr 23, 2016 07:17 AM
PistolPete83
Oct 27, 2013 09:10 PM
vistavette
Aug 9, 2011 08:49 PM
Sonny's World
Aug 29, 2009 10:07 PM
Morloka
May 20, 2008 08:05 PM
