Ape Hanger Conversion
Old Feb 17, 2008 | 01:02 PM
007dyna's Avatar
007dyna
Default Ape Hanger Conversion
Anybody out there done a handlebar conversion involving new cables, wire extension kit, etc.??
I'm contemplating taking my 07 Dyna with stock buckhorns up to a set of 13" apes.
Kamloops HD is quoting me $1200CAN and 7 hrs. Is this right? Is the operation really that complicated?
I would really love to hear some advice from dudes who have already done this. The good bad and the ugly!!
Thanks
Old Feb 17, 2008 | 01:18 PM
mattia's Avatar
mattia
Default RE: Ape Hanger Conversion
Total cost for my with cable and lines and about 5 hours of time was about 800.00. With 13" apes you mayget by with old connections.
Old Feb 17, 2008 | 01:23 PM
wfdmedic8's Avatar
wfdmedic8
I did 12.5" apes form the stock mini apes on my dyna, and had plenty of cable length. Do a search on this forum there was a guy who did a step by step on how to DIY that was a HUGE help!!! I can remeber the guys name sorry.
Here is the link I was able to find it: https://www.hdforums.com/m_1328001/mpage_1/key_/tm.htm
Old Feb 17, 2008 | 03:05 PM
reded's Avatar
reded
I'm currently waiting on my cables but I'm only into it for abut $350. Its a fairly simple install, just time consuming due to the wiring.
Old Feb 17, 2008 | 03:10 PM
007dyna's Avatar
007dyna
Thanks wfdmedic8
You're awesome
Old Feb 17, 2008 | 09:29 PM
JayFromPa's Avatar
JayFromPa
Let's see.............1200 Can should be about a billion dollars US right?
Seriously though, you can do this yourself. I did and and it really isn't a big deal. I internally wired my bars and so on by myself and it's a little time consuming, but nothing that can't be done over a couple of beers and a service manual. Thie time of year is the best time to tackle these projects since you sure as hell aren't going to be doing much riding.
If you need help let me know.
Old Feb 17, 2008 | 10:26 PM
07bobber's Avatar
07bobber
its not too hard.. a little time consuming. youll definatly need some kind of alcohol but it can be done with a little help. i spent about 450 on everything maybe 500......good luck.
Old Feb 17, 2008 | 10:49 PM
JRK5892's Avatar
JRK5892
dude do it yourself... get a camera, we can walk you though it... i did mine a few weeks ago, well the internal wiring at least, ws not hard and learned alot... could make it so much easier for the next guy... doing my girls bars next weekend...
Old Feb 17, 2008 | 11:04 PM
rok312's Avatar
rok312
Did mine myself. 16" Nash Gimps (which are in reality closer to 14.5-15"). Not terribly difficult, just time consuming as others have mentioned. I'm probably the exception, in that it took me a few weeks - but that is because I only had an hour or two here and there a few nights a week available to work on it. Could have done it over a weekend pretty easily. My Sig pic is the almost finished result - didn't have the brake line or clutch cable installed at the time the photo was taken.
Check out this thread - helped me a lot: https://www.hdforums.com/m_1328001/tm.htm
Old Feb 17, 2008 | 11:37 PM
Lone Watie's Avatar
Lone Watie
Do yourself - I knew nothing, but now know a lot. wiring was a little tricky at first, but mainly because was tired. all in all well worth it to do yourself. can't speak for cable length on your bike. i needed new throttle/clutch/brake, but wires were good to go putting 10 1/2 in on my fat bob. I'll be posting some pics/comments in next couple days to add to bestofindica's great thread. but, have to mention, has been very time consuming - friday before lunch until now, and still need to install brake lines tomorrow and bleed, then will be done. good luck.
