help with vibration
Old Feb 22, 2008 | 01:50 PM
rounder's Avatar
rounder
Default help with vibration
my bike seems to be vibrating heavily when I give it a little gas ... seems to be at a certain rpm range( no tach so I don't know the rpms but maybe 250-500 rpms above idle) does it sitting or riding.... all the mounts are tight.... any help would be greatly appreciated.
Old Feb 22, 2008 | 01:57 PM
kk6pg's Avatar
kk6pg
Default RE: help with vibration
there was a discussion recently about vibration, and having something to do with the front motor mount being stressed and weakening.
Dont know if its the same thing for you, but you might want to check it out.
I cant remember where I read this.
Then again, I have a hard time remembering my name too.
Old Feb 22, 2008 | 02:14 PM
Stanger's Avatar
Stanger
You can try a search with Vibration, here is one that someone did
https://www.hdforums.com/m_1991601/tm.htm
Good luck
Old Feb 22, 2008 | 02:18 PM
07bobber's Avatar
07bobber
ya i noticed a little more vibration on my bike in 5th gear. i guess i should check out my mounts.
Old Mar 3, 2008 | 08:52 AM
dynaglide07's Avatar
dynaglide07
check your mounts or plugs, if your plugs are going bad you will get alot of vib to. use ngk iridiums.
Old Mar 8, 2008 | 08:13 PM
WhatTaxi's Avatar
WhatTaxi
I dont know if u fixed it yet but ub & i fixed it by putting a thin fubber hand made washer between the brake & footpeg mount .
there was to much side to side movement inthe brake armand that made it 80% better , a piece or two from a pushbike tube or somthing like that.
hope this helps
Old Mar 8, 2008 | 09:31 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Hey Rounder have you checked your primary chain? There might be just enough slack to give you a chain harmonic vibration. If you don't already have one put in a M6 chain tensioner, they are the cat's meow. That's a good lookin 05.
hoghead5150
EVO
13
Aug 28, 2023 02:01 PM
stevequad
EVO
30
Nov 24, 2014 03:30 PM
see22ds
Jul 12, 2013 09:12 AM
newtsqueensy
Aug 30, 2007 08:23 PM
cravenc
Aug 22, 2007 02:46 PM
