LED lights flicker/pulse
Old Feb 25, 2008 | 04:37 PM
moblue's Avatar
moblue
6th Gear
Default LED lights flicker/pulse
i have changed my rear turn signals from incandecents to LEDs and added a load equalizer. i also have the run/turn/brake module. the lights flash as they should with the load equalizer installed, but they flicker/pulse a little when on steady as running lights. i also notice that when the turn signals flash the brake light dims briefly. the load equalizer i installed was the cheapest kuryakyn unit i could get with a 2 amp load. do i need a better equalizer, one with more or less load?
also note i have the equalizer upstream or battery side of the run/turn/brake module per the instructions that came with it.
Old Apr 16, 2008 | 08:58 PM
DEMIGOD's Avatar
DEMIGOD
6th Gear
Default RE: LED lights flicker/pulse
To the top.......I have the same issue!
Old Apr 17, 2008 | 01:30 AM
JRK5892's Avatar
JRK5892
all you need a resister pack... you can make one for about 3 dollars in stuff from radio shack... when i get up tomorrow i will give you guys a write up... I dont have all the right resister info here to do it... i work with LEDs all the time
Old Apr 17, 2008 | 03:52 AM
DEMIGOD's Avatar
DEMIGOD
6th Gear
Please post when you have time. I have the plug n play run/brake/turn harness installed from kury as well as their panacea led smoked out turns in the back. Hopefully I wont have to do much hacking on my bike.
Old Apr 17, 2008 | 07:21 AM
flynavy's Avatar
flynavy
Is the connector for the load equalizer tight?
Old Apr 17, 2008 | 04:06 PM
DEMIGOD's Avatar
DEMIGOD
6th Gear
ORIGINAL: flynavy
Yeah to the point where its a PITA to get it back out.
Old Oct 3, 2013 | 01:37 AM
dellagratti's Avatar
dellagratti
I know im resurrecting an old thread, but i was hoping to learn what i need to do to make a resistor pack so i can keep rear LEDs from flickering. Maybe JRK5892 can answer or anyone really???
Thanks in advance!
0maha
EVO
32
Oct 31, 2017 02:31 PM
RollinLowDeluxe
Apr 12, 2016 10:43 PM
MAGNYS
Sep 18, 2009 07:33 AM
bberck
Jul 16, 2009 03:48 PM
1nuckenfut
Feb 18, 2008 11:20 PM
