Brake light malfunction
Old Feb 28, 2008 | 11:36 PM
deadwood666's Avatar
deadwood666
6th Gear
Default Brake light malfunction
I just noticed on a long freeway trip home that my brake light does not work. I'm assuming that it just happened but I can't be sure. I'm awful with electrical stuff. Does anyone have any tips on whats wrong?
Old Feb 29, 2008 | 04:05 AM
jmpancoast's Avatar
jmpancoast
Default RE: Brake light malfunction
Does the brake light not come on at all? Does it come on and stay on? Have you had reason to mess with your right-side hand control recently? Does neither the front brake lever, nor the rear brake lever make it work?
Check some things:
[ul][*]Remove the taillight and check the bulb[*]In the housing which holds the bulb, check the harness plugs and make sure they are secure[*]Check plug connectors under the seat[/ul]
If all these look good, provide us some of the above requested information for diagnostics. Maybe someone here can help get you straight.
Old Feb 29, 2008 | 10:06 AM
dyna07custom's Avatar
dyna07custom
possibly burnt bulb? you dont have to be good at electric to change a bulb
Old Feb 29, 2008 | 01:05 PM
wkdavistx's Avatar
wkdavistx
Have you hit any potholes and bottomed out recently? Don't ask me why I ask that first.
Old Feb 29, 2008 | 02:24 PM
DGlide04's Avatar
DGlide04
Do your tail lights work? If the signals work, then there is power to the block in the tail lamp where the signals and brake light plug in. Start there, if there is power to the block, the problem is at the plug for the brake light or a bad bulb. Bulb is the place the start.
Old Feb 29, 2008 | 02:57 PM
wkdavistx's Avatar
wkdavistx
Actually, it's possible that the wire for the brake light is damaged somewhere without the turn signal wires being damaged.
BUT, your suggestion is the first place to start.
Gravel
Old Mar 1, 2008 | 12:12 AM
deadwood666
6th Gear
The brake light is always on and neither hand or foot control work. I have recently adjusted my right hand control. The brake light was flickering for a few minutes earlier today.
Old Mar 1, 2008 | 12:24 AM
HDHornet's Avatar
HDHornet
Check your housing to make sure it is put together properly, you may have lost the little clip that's in there. When you squeeze the brake lever you should hear a click. Check this post ou, it may help.
https://www.hdforums.com/m_2895763/tm.htm
Old Mar 1, 2008 | 12:40 AM
deadwood666
6th Gear
Thanks guys. That was the problem. I lost the little piece.......
Gratefulpipes1980
May 20, 2017 07:27 AM
supermanotorious
Apr 5, 2014 04:20 PM
sval
Aug 2, 2013 08:17 AM
tas_todd
Feb 2, 2011 07:09 AM
COFFESLINGER
Aug 31, 2006 09:12 PM
