Help
Old Mar 4, 2008 | 07:28 PM
mattia's Avatar
mattia
Default Help
I have a 2000 fxdl, with the idiot light mounted on an eyebrow by the head light.
I can't find how to release the lights from the brow. The clip is way down through the frame. Which don't make sense to pull all the way out to the head light to remove.
The little plastic lights are apart in three pieces. But can not pull brow out and away.
Old Mar 4, 2008 | 07:31 PM
mattia's Avatar
mattia
Default RE: Help
Trying to write what I see is a pain.
But, It looks like it was fed through the brow down theframe to the clip. Which seems like the long way around the fence post.
Old Mar 4, 2008 | 08:52 PM
Azgunner's Avatar
Azgunner
Default RE: Help
I don't quite understand what you're trying to do. You idiot lights should plug in to the wiring harness under the tank console. You'll need to pop the round cover over the nut or bolt that hold the headlight to the eyebrow & take the headlight off to access the underside of the eyebrow to get the idiot lights out of the eyebrow. Again, I'm not sure what you're trying to do.
Old Mar 4, 2008 | 09:36 PM
mattia's Avatar
mattia
Default RE: Help
You may be right about the wiring harness for the idiot lights being under the console. I took for granted it went to the main harness. I will get picks when I go to the shop tonight at 11:00 tonight.
Everything went smooth, until I had to remove that brow.
Old Mar 5, 2008 | 06:10 PM
mattia's Avatar
mattia
Default RE: Help
Azgunner thank's, It is under the console. I need to stop before three a.m. to see it. But the bad problem now is I have to pull my outer races in my neck. They have some wear, Harley did not grease properly, That iswhat it looks like.
Old Mar 5, 2008 | 07:06 PM
Azgunner's Avatar
Azgunner
Default RE: Help
Do you have a race removal tool? It'll be very difficult if not impossible to remove them without one due to the angle & shape of the neck.
Old Mar 5, 2008 | 10:48 PM
mattia's Avatar
mattia
Default RE: Help
Having the tool would be nice. But my Buddy who build's bike's, Tim Cauffman, From Thunder road cycles, said to put a small bead(weld)on the race and that gives you some thing to tap on for removal.
Where can I get the TOOL!
Old Mar 6, 2008 | 08:20 AM
Azgunner's Avatar
Azgunner
Default RE: Help
I've heard that can be done. You can buy the tool, $110 from George's Garage or I could loan you mine. I'll PM you.
mjr76ks2008
Mar 19, 2017 07:39 AM
Slowride2
Mar 25, 2015 04:20 PM
Jonathon Beaudin
Electrical/Lighting/Alarm
Mar 16, 2014 08:34 PM
UltraClassicElectraGlide
Aug 19, 2013 04:04 PM
Sniper318
May 30, 2011 07:11 PM
