question
Old Mar 16, 2008 | 07:21 PM
coastrider's Avatar
coastrider
Default question
I have ordered V&H staggered shorthots and still haven't decided on which ac to go with. I am looking at both the Ness big sucker stage 1 and the screamin eagle stage 1. I know i can use the OEM football cover with the big sucker. Can I use the football with the sc? The HD catalog doesn't specify. Which way do you guys suggest I go? Thanks for any input.
Ride Safe.
Old Mar 16, 2008 | 09:20 PM
2007fxdc's Avatar
2007fxdc
Default RE: question
ORIGINAL: coastrider
Ride Safe.
Both about the same as far as performance and you can use the stock football with either. I liked the filter on the ness better because, if it's not a K&N, it's a good replica. Both kits specify to use the stock a/c cover after you're done installing but you certainly have other options if you like. I run mine open with a HD a/c cover insert on the end but I can also remove 1 bolt and put the football on if I need to be concerned with excessive rain or anything like that.
[IMG]local://upfiles/41150/FAD48CB68DDF4B87B02773B32BFDAECD.jpg[/IMG]
Old Mar 16, 2008 | 10:29 PM
coastrider's Avatar
coastrider
Thanks fxdc. I like the football and have one in black denim to keep with the blackout look. Thanks again.
Ride Safe.
Maxxsmart
May 5, 2016 11:14 AM
cosmicHD
Mar 26, 2008 09:47 PM
royston
Mar 5, 2008 11:25 AM
Tat2u
Nov 23, 2007 07:02 PM
