cam selection/ performance advice???
Old Mar 17, 2008 | 05:51 AM
otaramc's Avatar
otaramc
Default cam selection/ performance advice???
Hi,
Ive got the T-Max with Auto tune on my 2oo7 FXDWG along with Arlen Ness Big Sucker A/C and a D&D 2into1 FatCat exhaust system.
Ive Just returned from racetrack and got a best time of 13.6 Seconds down the 1/4 Mile.
What cam selection would you recommend that would compliment my current system/ combination, to help me better this time. (Was thinking of sticking with ThunderMax Cams by Red Shift)
and what other mod/ part selection would you recommend that will help on the track as well as the street?
Looking for any ideas
Cheers
Old Mar 17, 2008 | 06:20 AM
SkyRider's Avatar
SkyRider
Default RE: cam selection/ performance advice???
All depends how nasty you want to go.
92-100+hp = SE heads, Woods Cams, Hi compression pistons, Dyno tune, roller rockers, roller rocker supports, gaskets, don't need a throttle body but a good thing to get
107+ hp = big bore 103"with everything listed above throttle body needed
115+ hp = 110" for really high hp builds SE flywheel recommended, and everything above need
all builds need new clutch spring
prices can range very much depending where you wanna go
hope this helps
Old Mar 17, 2008 | 06:31 AM
otaramc's Avatar
otaramc
... lastly what mods would help me get into the 100HP/100TQ club?
Old Mar 17, 2008 | 09:21 AM
the metal's Avatar
the metal
since ya already got the shiznit tmax, i would get one of the zippers big bore builds +tb to go with it
Old Mar 17, 2008 | 09:42 AM
Treasure's Avatar
Treasure
If only cams you might want to look at Andrews 54H....over on the v-twin forums you can find out a lot of info....gobs of riders are giving big props to these cams in the 96 incher......and for what it is worth GMR just punched my 06 bob out to 98 incher ported the heads and put in these new 54H cams. Just something to look into
Old Mar 17, 2008 | 10:35 AM
meyergsr's Avatar
meyergsr
Andrews 54H bolt in cam. Will get you close 100ft torque.
Old Mar 17, 2008 | 08:44 PM
jsbridgew's Avatar
jsbridgew
where the heck does one find Andrews 54H cams?...their website doesn't list them
Old Mar 17, 2008 | 09:15 PM
Treasure's Avatar
Treasure
All I can tell you on the 54H is that all the performance builders got their hands on them in early Feb....as I noted above GMR threw mine in the third week of Feb......I would think you can call Andrews or I think the dealers can get them if your going to have them do the install....the 54H is real hot right now and they might be hard to get your hands on.
good luck
Old Mar 18, 2008 | 07:30 AM
jsbridgew's Avatar
jsbridgew
wow...alright....thanks, man....i'm gonna start shopping around today....
i love the hunt!
Fat11Lo
Engine Mechanical Topics
41
Sep 13, 2017 12:08 PM
mja52403
Jul 30, 2012 09:15 AM
Prodriverdon
Exhaust System Topics
11
Feb 19, 2012 03:30 PM
otaramc
Mar 17, 2008 11:33 AM
tom73
13
Aug 1, 2007 10:44 AM
