Cam Chain Tensioner Inspection
Old Mar 18, 2008 | 12:19 PM
MarkM's Avatar
MarkM
Default Cam Chain Tensioner Inspection
I have an '05 WG with 31k on it (still under extended warranty), and after reading the posts about tensioners wearing out, I asked the service guy at my dealer about it. He said they would only replace them under warranty if they fell apart, not if they were just worn out. I asked about getting them looked at, and he said for $50 they'd pull the cover and have a look.
After reading through my service manual, it looks like that by just pulling the cover you can only see the primary tensioner, and to see the secondary tensioner you'd have to dig deeper. My question - is just looking at the primary tensioner good enough, that is, should both of them be worn about the same? Or do you actually need to get to the secondary one also? I'd rather have them replaced if they're worn rather than waiting for them to blow up and all the other damage that can cause. Any ideas? Thanks.
Old Mar 18, 2008 | 12:28 PM
wkdavistx's Avatar
wkdavistx
Default RE: Cam Chain Tensioner Inspection
When a cam chain tensioner falls apart the results can be disastrous. I've seen motors blow because chunks of plastic from the tensioners plug up the oil pump. I'd call it good practice to change them every 20 to 30 thousand miles, but I know people with many more miles than that without an issue yet. I've got about 42k on mine and about to do cams and top end... i'll replace them then.
The inner and outer could be worn differently. I'd definitely have both checked, but with 31k on the bike if I'm going to pay someone $50 to check them I'm going to go ahead and replace them. Probably cost you about $200 or $250 total, but worth it in my opinion.
Old Mar 18, 2008 | 12:33 PM
mud's Avatar
mud
Mark, davis says it pretty good.
Here's a series of pages that may be worth a look -
http://www.harleyhog.co.uk/tensionerinstall2.htm
mud
ORIGINAL: MarkM
XTonerman
2014-2024 Touring Models
17
Sep 12, 2020 09:29 AM
zeus33
Jan 3, 2015 09:58 AM
ironbyron
21
Oct 13, 2014 02:05 PM
uuscotty
Mar 6, 2014 07:46 PM
RussW4
Jan 21, 2012 07:30 AM
