Ya know there's a mod to tie those two breather vents into a tee and run them down a drain line that is snaked to the bottom of the engine and it just drains on the road. Think DAWG has done that. Whole point here, might be worth a try if even as a test to see if the problem is related to the breathers.
But, tank off and pulling the rocker covers is less than an hour's worth of work - top end gasket kit includes the breather parts as well. There is also a mod to drill the breather hole to a slightly larger diameter - again, Dawg pointed to that tip.
I did that same trick...ran the tubes down on my sporty.....its a cheap shot to see if thats where the problem lies, I'll probably be doing that sometime soon and keep my fingers crossed.
