Polyurethane Vs. Rubber Riser Bushings?
Old Mar 21, 2008 | 09:05 AM
Muddyape's Avatar
Muddyape
Default RE: Polyurethane Vs. Rubber Riser Bushings?
I went with poly long after I went to 14" apes. Wished I had done when I first switched.....to much movement in the bars. Not any real difference in vibration.
Old Mar 21, 2008 | 10:00 AM
Cornhusker's Avatar
Cornhusker
I made the switch to Poly when I went to WG bars and 3" risers. At first, I noticed a little vibration I hadn't noticed before but that only lasted about a day and everything seemed better. Goodsolid feel and I like 'em.
Old Mar 21, 2008 | 10:07 AM
sharkey's Avatar
sharkey
Put poly risers/Dyna bars with weight in the ends on my 100hp '01 Sporty and got less vibration...put 1200S bars on my 103 FXDXT and I think I got a bit more vibe but more solid feel. Brother has the HD Fat Mini Apes and we used poly in them, too; the rubber mounts felt too loose.
[IMG]local://upfiles/32069/6F84469F12284A4FAB573F78B7FE83EF.jpg[/IMG]
[IMG]local://upfiles/32069/7C7DA527A7A94561834FFF559B1351B1.jpg[/IMG]
Old Mar 21, 2008 | 10:22 AM
kerry_okie's Avatar
kerry_okie
I did the poly bushings, but didn't like the way it felt with the caps that came with them. So I kept the poly bushings and used the stock insert/washer to bolt them up - much better.
-- kerry --
Old Mar 21, 2008 | 12:02 PM
HogGlider's Avatar
HogGlider
Helpful tip...dont spend more than $12 for a set of pooly bushings...they are all the same material...just marketing for the price. Got a set of Drag Specialties bushings from Dennis Kirk for about $11 and have 6" risers...night and day difference and I have MUCH more control of the bike into corners than before....best upgrade IMO
Old Mar 21, 2008 | 12:31 PM
cspach's Avatar
cspach
I have Poly and my mirrors became less blurry (less vibration)
Spach
Old Mar 21, 2008 | 12:38 PM
98glider's Avatar
98glider
I use solid mount bushings and I have no problem on my 98 superglide
Old Mar 21, 2008 | 01:26 PM
twofish's Avatar
twofish
I just got these Drag Specialties bushings.
Old Mar 21, 2008 | 01:34 PM
HogGlider's Avatar
HogGlider
^Those are the ones I went with...best $11 I ever spent on my bike
Old Mar 21, 2008 | 01:37 PM
tattoofreaksb's Avatar
tattoofreaksb
Poly here also. Big difference in movement of bars. Can't really tell any difference in vibrations for me.
