Warming up the Harley
I usually let her warm up for about 5 minutes while I am getting geared up. The only time I don't is first thing in the mornings when I am riding to work. I let her idle for about 1 or 2 min max and head out. Its too loud to let her idle out there (I live in an apartment complex) any longer than that at 6:15 in the morning. I do take it easy on her the first couple miles and then push the choke in and wake up the neighborhood I happen to be passing through. I feel bad when its 35 deg out but what do ya do.
To each his own
How long do you guys usually warm up urbikes?
One of the Harley Techs told me that we are supposed to warm up
until the rocker heads are warm-hot then its ready to go.
and Never ride when its cold.
It usually took me 5 mins for the bike to warm up.
They said the purpose of this warming up is to swell up the bore and pistions
to allow the oil to roam inside the engine.
Without warm up, the piston will scratch the bore and damage the engine.
Correct me if I'm wrong.
I would like to hear your input about this - true or false and why. thanks!
Chris what you were told is true.
Your motor is engineered to operate within critical parameters.
If you put the machine under a load before the clearance tolerances
are into spec as designed, the pistons will be slapping against
the cylinder walls, scarring them and the piston skirts.
It really takes more than 4-5 minutes to allow for expansion
and normalizing to avoid subtle damage.
Hard to remember a topic where I have read more bullshit on a single page.
Key in, hit button, roll on it.
240 degress in one minute.
Get on it and ride, you won't notice any problems.
I don't want to wake up my neighbors.
On the other hand, several well informed replies to your query.
Below, is some real data, collected from the ECM of my 06TwinCam
on an 85F day last October.
mud........
Start Up
One Minute
Two Minute
Seven Minute
Eight Minute
Twenty Minute
everything i've read, written by so called experts, indicate that alloys used in engine manufacturing and modern day oil have almost eliminated the need for warm ups. i still think it should have time to 'warm up' i just think it doesn't take as long as 5 minutes which is about how long it took for the old truck to warm up when i was growing up.
Looks like your data shows a few minutes needed to let the bike warm up a bit before putting any load on the engine.
Looks like more time and highway miles needed before hammering the throttle, than just a couple minutes.
Somebody on here gonna ask you why you're doing 88 mph in 4th, though....... musta just shifted, huh??
Got my SERT today. Have to wait for the cables to come in, then I'll be lookin at my own graphs
Hey riding season starts around here in a couple more months........ means my bike will never really cool down very much. I'm getting rides in 2-3 days a week right now, mostly to the dealer and gas station.
Thanks fer sharing.
DougJ
Mud,
Thanks fer sharing.
DougJ
Doug, I assume you picked up the new generation SERT.
Here is a snapshot of that entire Data Collection run.
Trial run # 19.
I have an eight mile course that I run each time,
so I can compare apples to apples.
City streets, highway, uphill and down.
mud.......
edited to add - RPM is wrong, cause I had pulled in the clutch.
RPM should read 5298 (back up the Blue Line a couple frames)
picture 2
For whatever reason, if I don't let it go the two minutes or longer, the gas mileage drops below 59 MPG.
Still haven't figured that one out.
JC
I twist the throttle once and hit the starter
kick stand up put it in gear and leave..
now I live in a gated area so have to ride slow then on city streets for a mile or so
before I can get into it
but warm up never but then it only has 40 thou on the engine
04 softail std.
glad to hear I'm not the only one tho.. mileage is mid 40s
[IMG]local://upfiles/5757/BFEEF0F1ED994E3A948AC8FCC38C175A.jpg[/IMG]
How long do you guys usually warm up urbikes? One of the Harley Techs told me that we are supposed to warm up until the rocker heads are warm-hot then its ready to go. and Never ride when its cold. It usually took me 5 mins for the bike to warm up. They said the purpose of this warming up is to swell up the bore and pistions to allow the oil to roam inside the engine. Without warm up, the piston will scratch the bore and damage the engine. Correct me if I'm wrong.I would like to hear your input about this - true or false and why. thanks!
