Adjusting "fall away"
Old Mar 28, 2008 | 09:16 PM
SPECIAL ED's Avatar
SPECIAL ED
Default Adjusting "fall away"
Alright, I know this was discussed not too long ago but I wasn't paying attention because I didn't think mine was in need of adjustment so bear with me.I just had my bike in he shop last week for tires and they told me my "fall away" needed to be adjusted.What is it?Who's done it? How hard is it? enlighten me.
Old Mar 28, 2008 | 09:25 PM
SeeNoSun's Avatar
SeeNoSun
Default RE: Adjusting "fall away"
Don't know much about it but I was told by a dealer mine was off after he test rode it after a dyno tune. A week before the tune I had it in for service at another dealer to have the fork stem washer replaced because of looseness in the front end. After the washer was replaced the front end seemed worse.
I paid the dealer that did the dyno tune and said I needed the fall away adjusted an hour of labor and the front end was much better. I recommend letting someone that knows what they are doing perform this repair. It is well worth it if your front end does not feel right to you. I'll never go back to the first dealer for service.
Old Mar 28, 2008 | 09:27 PM
Gadgetech's Avatar
Gadgetech
ORIGINAL: SPECIAL ED
I'm not exactly sure you couldn't solve any of those questions w/o Viagra. When I was a kid I heard "it" referred to it as a camaro pulling into the garage but if you want to call it a bike in the shop, that works I guess.
Old Mar 28, 2008 | 09:36 PM
hk_shooter's Avatar
hk_shooter
ORIGINAL: Dynamite
[sm=icon_rofl.gif]Oh, man, I just wasted the better part of a good drink on my keyboard.
Old Mar 28, 2008 | 09:41 PM
BoomSoon's Avatar
BoomSoon
OK So let me see If I can help you here. I have had a small prob on decel in 1st gear I get a little knock in the front end and I get a little pull to the right in my steering. I swear I can hear it but I know I feel it. Something loose? My dealer did all the workup including what I beleived was something like what you are talking about. They get the bike up and see which way the wheel turns/falls and so on and they can check for steering issues. There are certain HD variables that allows them to measure this "fall-away" or whatever and determine if an issue or not. Hope thatmde since
[IMG]local://upfiles/54962/30F2C02C56694288A76A9AC2283DF311.jpg[/IMG]
[IMG]local://upfiles/54962/D9D4D71FC029452BA236DAC01252DDD6.jpg[/IMG]
Old Mar 28, 2008 | 09:59 PM
Elginator's Avatar
Elginator
...they told me my "fall away" needed to be adjusted. What is it?...
OK, can anybody put it into words? What is "fall away?"
Old Mar 28, 2008 | 10:06 PM
dynasty's Avatar
dynasty
"Fall Away' is described in teh shop manual (which everyone should own so one doesn't have to go to the stealer for everything).
i don't have the manual right in front of me but it goes like this.
Raise bike so front wheel is off ground and can travel full range
Line front tire straight with bike/frame and mark center on floor with tape
Ensuring the clutch cable is not an influence (removing it from handlebar is best way), carefully (slowly) move tire to either side and mark the point at which it starts to 'fall away' on its on.
Mark and measure both sides. it should around 4".
If less than 4", it's too loose - more than 4", it's too tight and you adjust the fork nut accordingly.
will have to go look up the torque value - pm me if you need it
Old Mar 28, 2008 | 10:10 PM
glide05's Avatar
glide05
ed -
"fall away" is basically the effort that is required to push a neutral front end (centered on a lift) to one side or the other. If your stem is too tight - it will require too much effort - if your stem is too loose - it will flop over by itself.
the manual details the procedure.
you will need to remove your clutch cable from the left side as that influences the numbers.
it's a pretty wacky procedure - although you can certainly do it yourself in about 1 - 1.5 hours
Old Mar 28, 2008 | 10:59 PM
BoomSoon's Avatar
BoomSoon
Dynasty, Thanks....So much more succinct than my sputtering. I knew what it meant but cant beat the book.
Old Mar 28, 2008 | 11:09 PM
ssls6's Avatar
ssls6
I just finished doing my WG a week ago. Here is the procedure:
1) Loosen steering stem nut (may require you remove the bars and put them back)
2) Loosen the pinch bolts (top triple tree)
3) With bike off the ground, center up the front wheel
4) Now push the wheel to one side slowly until it falls away, if the front of the wheel moves less than 2" before fall away, it is too loose
5) Adjust the star nut below the top triple tree with a punch and hammer to adjust fall away to meet the 2" spec
6) Torque top steering stem bolt (70-80 ft-lbs on my WG)
7) Torque pinch bolts on top triple tree (32 ft-lbs on my WG)
