headlight harness help
Old Mar 29, 2008 | 01:30 PM
jasonyankees's Avatar
jasonyankees
Default headlight harness help
I am changing my headlight with a newer one. The harness with the plug attacment goes into the neck of the bike. Any suggestions on how to get it out. Im wondering if there is slack in it and I can just pull on it. I have a 2006 Superglide and the hole is on the right side of the bike.
Is it difficult to change ?
Thanks
[IMG]local://upfiles/52091/8421583C383946348DAE7B638D70C607.jpg[/IMG]
Old Mar 29, 2008 | 01:35 PM
BLade1127's Avatar
BLade1127
Default RE: headlight harness help
Too difficult for a Yankees fan!!! Take it to the dealer!! J/K!!
You could always splice into the harness. If not, pull out the rubber grommet on the neck and see if it gives you access. Most of the wires are easiest to get to from a panel located under the backbone, but it can be time consuming. There are posts on here giving all the details, just use the search feature.
Old Mar 29, 2008 | 01:39 PM
jasonyankees
Sad but true , more than likely to difficult for this yankee fan
LOL
Thanks
GO GIANTS
[IMG]local://upfiles/52091/0312AB8B92BC4950AE651DA2421E4F7A.jpg[/IMG]
Old Mar 29, 2008 | 01:40 PM
BLade1127's Avatar
BLade1127
It's not hard at all.
Old Mar 29, 2008 | 05:45 PM
jmpancoast's Avatar
jmpancoast
As mentioned, pulled the rubber grommet from the neck. Unbolt the front of the tank. Lift the tank and slide a 2 x 4 under it. Don't let the tank slip and hit and scratch the rockers boxes. Remove the plastic cover from the bottom of the backbone. Jiggle the headlight harness from the side of the neck while you are feeling the wire from the underside of the backbone with a couple fingers. You should be able to find the connector like this. Then just feed it through so you can access it from the side. There is a lip in the backbone which sometimes will keep the connectors from pulling through. Just move it around till it is out of the way of the lip and you should be in business.
BigHoss
Electrical/Lighting/Alarm
Jun 2, 2017 11:28 PM
bagman1
Dec 23, 2013 12:43 PM
solow
General Topics/Tech Tips
Mar 29, 2011 09:40 PM
jam65
Apr 26, 2009 08:20 PM
AmmoDan
Jan 11, 2009 10:41 PM
