Fork Cap socket size
Old Apr 1, 2008 | 06:46 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Default RE: Fork Cap socket size
Hey Airborne, if you are planning on changing fork oil, from what I understand there isn't a drain plug on the newer forks. They have to be removed from the trees. That means the front tire has to come off. Nothing easy any more. If you are doing spring work, do one side at a time unless you have a jack under the bike to support it when the springs and front forks unload on you. Don't ask howI know about this.
Old Apr 4, 2008 | 11:20 PM
rayfinseats's Avatar
rayfinseats
Mineare big crescent sized. That's some funny sht right there.
Old Apr 4, 2008 | 11:55 PM
pwer pla's Avatar
pwer pla
Just did mine (07 WG) and the socket was a 1 3/8. If I remember right 1 1/4 was too small. Only place I found a socket that big was the local farm supply store, sears didn't have it. Also had to buy a reducer so I could use my 1/2 in socket wrench. IMO easier to use then a cresent wrench, the caps are fine threaded and are kinda a bitch to get started, with the socket i could apply equal pressure. Couple tips that I found out the hard way. Don't accidently drop the cap on the cement garage floor it will f/u the threads causing you to go one a three state search for a replacement. Also when I put the caps back on I put the fork tubes back in the triple trees first to hold them steady. It was much easier than trying to hold them and start the caps. Hope this helps.
IrishHick1776
Jan 28, 2019 02:29 PM
memphisharley
Jan 25, 2018 07:18 PM
WHOSNEXT
Jan 3, 2018 08:50 AM
Keithhu
Oct 17, 2010 05:43 PM
scrawfordFLSTC
Jun 2, 2007 10:37 AM
