front brakes
Old Apr 15, 2008 | 03:04 PM
bikerdog134's Avatar
bikerdog134
Default front brakes
i finished putting everything back together after internal wiring. i have 2 problems. first, how much of a pain is it to replace the brake light switch, second , i have no front brake. i opened the resovior and it was full. i squeeze the lever and it goes all the way down with no resistance. i try to punp them and nothing. any advice would be appreciated.
Old Apr 15, 2008 | 03:59 PM
ranger140892's Avatar
ranger140892
Default RE: front brakes
No resistance at all? If there are no obviously huge leaks, I'd saythe master is bad. I've never been inside a Harley master cylinder but I imagineit has a piston like other MC's. Those pistons have seals that can go.
Old Apr 15, 2008 | 04:06 PM
bikerdog134
thanks for the feedback. it has no resistance at all. what botheres me is that before i did the wiring , they were fine. cant figure it going bad just sitting there. thanks again
Old Apr 15, 2008 | 05:57 PM
soup48's Avatar
soup48
Did you change the brake lines or loosen the brake likes. I had changed my line in the front on both bikes and it took me a while to get it bleed. Remember, you have at least four pistons on the caliber.
Old Apr 15, 2008 | 07:31 PM
bikerdog134
i went back in the garage and squeezed on them some more. i do have brake but not much. ill get my wife out there tomorrow and get them bled. i also need a new brake-light switch.hope thats not too much of a pain. thanks for the info
Old Apr 15, 2008 | 07:42 PM
jmpancoast's Avatar
jmpancoast
The brakes are a bitch to bleed. I found the easiest way to do it is to invest $30.00 in a manual vacuum pump. Five minutes and they're bled.
Are you sure you brakelight switch is bad? If the retaining clip comes out, the switch will not be stationary enough to work. Also make sure the master cylinder clamp is seated properly where is meets the switch housing.
If both of these are good, the switch is $25.00 and easy to replace
Old Apr 15, 2008 | 08:09 PM
macatak39's Avatar
macatak39
Replacing the brake switch is easy to do. Just remember to have a business card, match book or something similar. You will need these
to hold your brake lever in just slightly so you do not break your switch again. From experience on doing this w/o card
Old Apr 16, 2008 | 07:57 AM
bikerdog134
ill check for the clip. i think the light is on and wont go off thanks for the replys
Old Apr 17, 2008 | 07:43 AM
bikerdog134
checked it out .its the spring clip. i will pick one up today thanking everyone for all the feedback
Old Apr 17, 2008 | 08:02 AM
Livi1215's Avatar
Livi1215
The switch is easy to replace,like the others said watch the switch close or when you take the control apart pull the lever in then line everything up. The brakes,I just put new pads on my front caliper had the same problem,pull the lever in and zip tie it to the grip so it's pulled in and let it sit for a while the longer the better,I let mine sit over night. This trick I found in the do it yourself thread on here.
