Ignition Switch Cap #@!%#
Old Apr 15, 2008 | 05:37 PM
RKLeo's Avatar
RKLeo
Default Ignition Switch Cap #@!%#
Today my ignition swich cover cracked off when I opened it.
LuckilyI did not lose the pin, but the little tack weld on the top cracked. Now its very loose and I will lose the pin.
Do they sella replacement cover?
Old Apr 15, 2008 | 05:51 PM
DougsDyna's Avatar
DougsDyna
Default RE: Ignition Switch Cap #@!%#
Don't know, but Eastern Performance has the entire switch for $23.
DougJ
Old Apr 15, 2008 | 06:36 PM
maddoggreene's Avatar
maddoggreene
Almost positive the switch is all one unit--no pieces or parts available. Sorry man!
Old Apr 15, 2008 | 07:39 PM
RKLeo's Avatar
RKLeo
ORIGINAL: DougsDyna
DougJ
That looks promising.....Thanks.
Can I assume you just remove the two bolts, lift the console and popthe new switchin effortlessly??
Old Apr 15, 2008 | 07:55 PM
DougsDyna's Avatar
DougsDyna
I think your switch probably mounts to a bracket on the tank, or to the console with some screws. Should not be a difficult replacement.
Hope someone with a 2005 WG jumps in here. Sure not a big deal.
Switch wires should just plug in.
DougJ
Old Apr 15, 2008 | 08:07 PM
RKLeo's Avatar
RKLeo
It looks like two bolts will lift the console. I dont know what it looks like under there.
Looking at the switch on eastern performance, I think it will be plug and play.........I hope
Thank you, I appreciate the EP tip.
wescoot2's Avatar
wescoot2
Just a thought.....if you go aftermarket for the switch, you will need 2 keys to unlock your scoot, that is if you lock your forks.
Respects,
Ed
Old Apr 15, 2008 | 08:55 PM
amish's Avatar
amish
ORIGINAL: wescoot2
Respects,
Ed
i was told in a thread awhiel back that you can rekey the new switch to use your old key i think if i rember right the guy said $30 or so at a locksmith shop
hharper40
Feb 13, 2018 10:58 PM
leathernutz
EVO
Oct 13, 2016 07:58 AM
motorcycleboy
2014-2024 Touring Models
May 11, 2014 11:56 AM
VETERAN75
May 29, 2013 11:11 AM
greybeard6
Electrical/Lighting/Alarm
Apr 21, 2009 02:30 PM
