Dyna down!!!!!!!
Old Apr 27, 2008 | 07:24 PM
Badmonkey's Avatar
Badmonkey
Default Dyna down!!!!!!!
Well my bike has less then 200 miles and less then 2 weeks old bought a Dyna StreetBob as my first bike and i love it. Hurt my feelings when i dropped it and the gear shift lever put a lil crack in the outer primary cover causing my bike to bleed a little bit. I dont know much about wrenching, and i was wondering if this was an easy fix, something i could do myself. I would apreciate any feedback on this.
Old Apr 27, 2008 | 07:37 PM
RAWHIDE07's Avatar
RAWHIDE07
Default RE: Dyna down!!!!!!!
OK,the outer primary cover can be replaced easily but if you are not concerned about cosmetics JB WELD will fix a small crack.
Old Apr 27, 2008 | 07:38 PM
NHHog's Avatar
NHHog
Check out the rplacing the primary cover section of the manual if you have it. My manual is in the shop or I'd look at it. I would imagine if you are half way capable with a wrench you could do it. I would check aftermarket places for the cover as it would be cheaper than the stealer. I am guessing it is an 08. You may have to get that from the dealer and that will probably run 3 to 350.
cudabob
Jun 7, 2017 08:27 AM
Joboo1966
Nov 24, 2012 04:05 PM
02LowRiderFla
Jun 8, 2012 02:04 PM
Raiderse
Jul 26, 2010 04:25 AM
HogBack
Jan 13, 2007 09:09 PM
