Will be picking up my bike next week. I too dislike the emblem. Back on 2/16, Adrenaman wrote he removed it. I am new back in bikes and don't want to f-it up? How did you do it and keep the finish. Mako[sm=crossbonesgif.gif]
To remove the emblem I used waxed dental floss, masking tape, 3M advesive remover and a pair of gloves. All purchased at Wal-Mart.
I put a strip of tape in the middle of the emblem to prevent it from falling off.
Then I put on gloves and doubled up some waxed dental floss and sawed the floss under the emblem. The floss would break every inch or so, so I would repeat the process. After The emblem was removed I taped some cotton rags under the tank to prevent the 3M adhesive from dripping on the motor. I then sprayed the left over adhesive witht he 3M adhesive remover. Then wipped the drippage and let it sit for a few min. I used my fingers to rub off the remaining adhesive. It came off pretty easy. The dental floss kinda left a haze on the clear coat of the tank. No prob I used Meguires fine scrath and swirl remover and it was good as new the used meguires paste wax to shine her up. The whole process took like an hour.
If it is attached with double-sided tape this should work.
heat with hair dryer or heat gun. they should pull right off. If not, use a piece of monofillament fishing line to saw it off. Clean up with goo gone of goof off.
